Hi, so I’ve been trying to make a config for the Anycubic Kobra and I can’t get it to work because they made weird stuff on their motherboard
Here is the config: [stepper_x]step_pin: PA5dir_pin: PA4enable_pin: !PC3microsteps: 16rota - Pastebin.com
Here is their Marlin source code: ANYCUBIC-3D/Kobra (github.com)
And here are all the information I have:
- In pins_AC_TRI_F1_V1.h in the source code you can find the USARTS at the bottom and all the pinout
- In Configuration_adv.h in the source code you can find the addresses they use line 2514
- A guy on Reddit said: 1. “3 TMC2209 (X=0, Y=1, Z=2 addr) and one 2208 (E0 and it’s without addr) on same UART The thing is it causes Klipper to not work because X and E are on the same address”
- He also said he was able to make it work doing this: “I’ve removed R65 and made wire to C65 (+5v) so new adr for X got 3 and it worked like a charm.”
- If I set the extruder to TMC 2208 on address 0 I can make it move (before Marlin stops the printer because it cannot communicate with the motor)
- If I set the X to address 0 it also works before Marlin stops the printer
For now I’m stuck, I have no idea how I can make this work, considering it works on Marlin
Thanks in advance!
