Unable to connect to mcu on kobra 2
Printer Model: Anycubic Kobra 2
MCU / Printerboard: trigorilla pro b v1.02
Host / SBC Raspberry pi 3b+
klippy.log (63.9 KB)
I am unable to connect to the mcu for some reason, I dont know why.
Have you tried
serial = /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
restart_method = command
Hi, I have just tried this but it isn’t the fix.
Have you tried different USB cables.
Is the MCU flashed properly?
Yes, I have multiple cables that I have tried, i have used power and data cables but same problem.
How can i check if the mcu is flashed properly?
Are you still having problems?
post log.
When you run the flash command, the output tells you if the flash is complete. You can use lsusb in the terminal to see if the hardware is connected.
Captura de tela de 2024-09-16 14-48-40
