Unable to read tmc uart ‘extruder’ register IFCNT
VORON 2.4 (SPECIAL EDITION)
MONSTER8 V2 + RPİ 4 MAİNSAİL
klippy.log will be added as soon as possible
Hello.. my new problem is “TMC2209 stepper driver: tmc uart ‘extruder’ register IFCNT cannot be read”… When I want to feed filament to adjust the extruder, I receive this error message and the system shuts down. Motherboard monster8 v2 - driver tmc2209. In my research on this issue They suggested “set the TMC2209 uart_address option to 3”. . But I don’t know how to change the uart address.
It’s an interesting situation. There is an x - y -4z engine on the motherboard. but I’m getting this error in the extruder driver. There was a spare 2209 Drive. I changed it… I reconfigured the exrtuder connection to the 7th output on the main board. I got the same error again. I changed the jumper settings from tmc-uart to step/dir. The result did not change. When I give a command to the extruder engine, the system gives an error… I cannot get a response to the “DUMP_TMC STEPPER=stepper_e0” command. I get the response “The value ‘stepper_e0’ is not valid for STEPPER”… I tried all its variations such as e, e1,e2 ,e3, e4, E, E0, E1, E2, E3, E4, extruder… Unfortunately, I did not get any results. Please, I really need your help on this matter… I don’t know which way to go anymore.
