Unable to read tmc uart ‘stepper’ register IFCNT
Background
The error “Unable to read tmc uart register IFCNT” indicates that your printer’s microcontroller unit (MCU) has failed to communicate with a specific TMC stepper motor driver. This communication happens over a serial interface known as “Universal Asynchronous Receiver/Transmitter” (UART).
Note:
- Klipper can identify which driver it failed to communicate with (e.g.,
stepper_x), but it cannot determine why the communication failed. The root cause is almost always a physical issue with power, wiring, or hardware configuration that must be diagnosed and fixed manually.- The reference to the TMC register
IFCNTis a “red herring”. This error is related to a UART communication problem, and not to a specific TMC register.
Causes and Potential Solutions
The klippy.log will confirm that this error occurred, but will not indicate the specific cause. A systematic, hands-on approach is required to identify and resolve the issue. Work through the following potential causes, ordered from most common to least common.
No or Insufficient Motor Voltage (VM) to Drivers
This is the single most common cause, especially on new builds or after wiring changes. The printer-board’s logic may be powered, but if the supply voltage jumper is set incorrectly or the motor power is not properly connected, the drivers will not receive power. This error will typically appear for all drivers at once.
Important:- Many printer boards have multiple jumpers related to supply voltage. The most common are jumpers that select between USB power and main supply power for the board. For regular operation, only the main power supply may be used.
- Some boards include additional power terminals specifically for the stepper drivers, along with hardware jumpers that select whether the drivers are powered from these dedicated terminals or from the board’s main supply. The jumper settings and wiring connections must match the intended configuration.
Incorrect Printer-Board Jumper Settings for UART Mode
Most printer-boards use physical jumpers to configure the driver sockets for different modes. For UART communication to work, these jumpers must be set correctly. Carefully check the communication mode jumpers against your printer-board’s documentation. -
Faulty Wiring or Loose Connections
A bad crimp, a loose plug, or a damaged wire in the motor cable can interrupt communication, often causing the error for a single axis. Visually inspect all cables and plugs for damage or improper seating (e.g., bent pins). Double-check the orientation and seating of the driver module. If only a single axis is affected, swapping the drivers and connectors (e.g., X with Y) is a good diagnostic step. If the error moves to the new axis, the issue is with that motor or its cable. -
Incorrect
uart_pinDefinition inprinter.cfg
Even with correct physical wiring, communication will fail if the firmware is set to use the wrong MCU pin. This is a common mistake when using a generic or outdated configuration file that doesn’t match your specific printer-board revision. Match the configuration against the board’s official pinouts, schematics, or default configurations. -
Driver Module Not Enabled for UART
Not all TMC driver modules come ready for UART mode out of the box. Some brands (e.g., Watterott, older MKS or Fysetc versions) require a physical modification on the driver PCB, typically by soldering a bridge across pads to enable the UART pin. Research your exact driver type and consult documentation to determine the required modification. -
Faulty Stepper Driver Module
The driver module itself can be defective out of the box or may fail over time due to static discharge, overheating, or voltage spikes (such as unplugging motors while powered on). If the error is consistently tied to a specific driver regardless of socket, the module may be faulty. Swap the suspect driver module with a known-good one. If the error is resolved, the driver is likely at fault. -
UART Bus Conflicts with Other Devices
This is rare on modern boards with dedicated UART pins for each driver. However, conflicts can occur on older or simpler boards if the same serial pins are used for both a driver and another device, such as an LCD display. Simplifying the setup by removing additional components can help isolate this type of issue. -
Other Reasons
These are less common but can be worth considering, especially when dealing with Heisenbug errors:-
Power Cycle: Fully shut down and power off the entire system. Wait to ensure all components are fully discharged before restarting (at least 60 seconds).
Thermal Issues: Make sure drivers are not overheating due to lack of ventilation or excessive current, as this can cause erratic errors.
Firmware Reflash: Reflash the MCU boards with a new firmware build, verifying the settings. This is especially helpful after Klipper updates, though typically not needed unless Klipper reports a protocol mismatch.
Remove Modifications/Extras: Temporarily remove any code modifications or extras, especially those affecting the drivers or TMC tuning.
Defective Board: While rare, printer-board defects do happen.
EMI/ESD: While usually not an issue for drivers seated directly on the board, avoid running high-current wires over or near the drivers to reduce interference risks.
