Unable to SSH into printer after updating moonraker
Ender 5 Plus Mercury 1.1
Manta M8P V2
CB1
Unable to access
Hello all! About a month ago I was having troubles setting up the timelapses for my printers when I realized a bunch of my programs were outdated. I decided I would update them, starting with moonraker, to see if they helped solve the issue. After I had gotten frozen on the %100 screen for about half of a day, I decided to cut my losses and go to bed. When I woke up I realized I could no longer access my printer. I couldn’t SSH into it, however what peaked my curiosity, was the fact that all of my fans turned on like they normally do in the config. I also noticed my Knomi V1 is saying to restart it, or check the internet connection. Any clues as to what is causing this is appreciated!
Please read: How-To Ask for Help
Can I know what I did wrong with my question? The main thing I see is the log but I physically cannot access it.
This seems to be a Linux issue. The best approach is to connect a screen and keyboard and monitor the boot process and then log in directly and troubleshoot according to the relevant OS logs etc.
I am unsure how to do this, I did attach a screen and I can confirm it is a problem with moonraker as it is connected to the internet. However, my klipper screen won’t let me get beyond the failed to connect to moonraker screen. Any ideas?
Have you tried turning it off and on again?
Yes I did, I just ended up resetting the printer and starting over again, luckily I still have my printer config.
