Unable to update klipper on Sovol Zero toolhead MCU
Printer Model: Sovol SV08 Running a ZERO toolhead with BTT U2C Adapter
MCU / Printerboard: Sovol SV08 Silent 64-bit Mainboard with Advanced TMC2209 Drivers
Host / SBC CB1_Debian11_minimal_kernel5.16_20240319
klippy.log klippy.log (3.1 MB)
…I recently installed a ZERO toolhead running EDDY NG on my SV08. It was working great until just recently when there was a klipper update. Now I am no longer able to update the toolhead MCU even after reflashing the firmware on the toolhead. I have backed kllipper to Version v0.13.0-264 and successfully update the main board MCU after reflashing the firmware but I was not successfull reflashing the TH MCU. Even though they all say they are at v0.13.0-264. Here is the error I am getting. I have good communication with the CAN adapter. But I do not get the TH UUID when I run a query. Any help is greatly appreciated.
this is the error I am getting.
Is the toolhead MCU still on Sovol’s bootloader or have you managed to get Katapult to flash?
the ZERO toolhead comes with Katapult already on it but after I started experiencing porblems I have reflashed Katapult to it.
Have you tried this?
Note the path and filename for the .bin file.
Well I just discovered that by uninstalling EDDY NG and replacing the EDDY NG commands in printer.cfg with the ZERO commands for EDDY I get a clean startup. So now I an going to do all the updates to the latest klipper and if I get a clean start I will reinstall EDDY NG. I will report back
I am still unable to update klipper to the toolhead MCU but no problem for the main MCU and I was following the esoterical guide and I used this script to troubleshoot the py files.
wget -qO - debug.esoterical.online | sh
You can see the file here. Hoping you can make any sense of it.
https://termbin.com/eid0
I did try the extra_mcu_upate_fw.sh after changing the file locations and the UUIDs. I am not 100% which UUID I should be using for the bootloader. The default one is 61755fe321ac and the one I originally got from the 1st querry is 27ed790d8665. This is what I used to try and update it.
echo “Start extruder_mcu_update_fw.sh now!!!”
if [ -f /home/biqu/printer_data/build/extruder_mcu_klipper.bin ]; then
if [ -f /home/biqu/printer_data/build/flash_can.py ]; then
    echo "Found flash_can.py"
else
    echo "No flash_can.py found in /home/biqu/printer_data/build. Exiting..."
    exit 1
fi
echo "Get into bootloader ..."
python3 ~/printer_data/build/flash_can.py -i can0 -f ~/printer_data/build/extra_mcu_klipper.bin -u 27ed790d8665 &
check_pid=$!
sleep 5
kill $check_pid
bootloader_id="27ed790d8665"
echo "Using default UUID $bootloader_id for firmware update."
echo "Flashing MCU firmware with UUID: $bootloader_id"
python3 ~/printer_data/build/flash_can.py -i can0 -f ~/printer_data/build/extra_mcu_klipper.bin -u "$bootloader_id"
if [ $? -eq 0 ]; then
    echo "Firmware update completed successfully!"
else
    echo "Error: Firmware update failed."
    exit 1
fi
else
echo “No extruder_mcu_klipper.bin found in /home/biqu/printer_data/build. Exiting…”
exit 1
fi
this is the only thing I see that I don’t like in the debug file. I am thinking I need to reflash the firmware to the toolhead with the ST Link. Thoughts?
Screenshot 2025-09-17 125625
Is the klippy service running on the host computer?
Not when I try to flash.
All good now. I had to reflash the zero firmware .bin file to the toolhead and then was successful installing the latest klipper to it. Thanks for the help.
