Untangling my Beacon and mesh settings
Printer Model: LDO Voron 2.4 Rev. D
MCU / Printerboard: NHK?
Host / SBC Rpi
klippy.log.zip (2.3 MB)
I am working through the setup of this machine and finding some issues. Of course one thing leads to another.
The start of this was horrible problems with the Beacon. Out of 20+ tries, one might succeed and get through the probing sequence. Standard deviation was larger than the limit. I adjusted to take five samples rather than three, and bumped the limit up a bit, and now that’s working reliably.
I noticed that at the beginning of probing the bed, the printhead moves to the right, but the Beacon is behind the printhead. Obviously this is not correct, and I was able to set the proper offset so that now the printhead moves forward such that the beacon coil is centered over the spot where the nozzle touched previously. (yay!) At the moment I’m using a Y offset of 15 because of a certainly related issue I’ll get to.
In working through the beacon config, the docs say that the Z offset is REQUIRED and yet putting in any Z offset gives me an error. So I’ll leave that for the moment though I would like to make it right.
At this point, I’m close to getting it working right, except that after running the tilt adjust, I’m getting an error: Move out of range 20, -10 2 [0] I assume it’s objecting to the Y move of -10?
So I suppose there’s a move buried in the call to Bed_Mesh_Calibrate?
I assume this has something to do with my correction to the Beacon settings, but how do I get past this?
I just confirmed that my Y offset was “causing” the problem, but without the right offset, the coil isn’t looking at the place where the nozzle was…??
My assumption (not seeing it clearly stated) that the purpose of those offset numbers is so that the beacon coil is centered over where the nozzle was when it probed using the nozzle. Am I wrong?
This machine is 300x300mm
LDO Leviathan controller
Voron Stealthburner (Is the beacon offset documented somewhere?)
I added a bunch of respond messages to get it debugged to this point.
*; --- Probe/level/mesh ---*
RESPOND TYPE=echo MSG="Probing"
BED_MESH_CLEAR
SET_GCODE_OFFSET Z=0
G28 Z
G0 Z2 F6000
G28 Z METHOD=CONTACT CALIBRATE=1
RESPOND TYPE=echo MSG="Tilt Adjust"
Z_TILT_ADJUST PROBE_METHOD=CONTACT
RESPOND TYPE=echo MSG="Bed meshing"
BED_MESH_CALIBRATE RUNS=2  ←— Error happens here
[beacon]
serial: /dev/serial/by-id/usb-Beacon_Beacon_RevH_BEC73BF45157355957202020FF0E2E17-if00
x_offset: 0 # update with offset from nozzle on your machine
y_offset: 15 # update with offset from nozzle on your machine
;z_offset: 10 # While the beacon documentation says that the z_offset is REQUIRED, uncommenting this line results in an error.
#****** DVH **************************************************************
autocal_sample_count: 5
# Number of samples used for each autocal.
autocal_tolerance: 0.01 ; Bumped this up because of excessive failures in probing.
# Acceptance tolerance for an autocal result.
autocal_max_retries: 5
# Number of retry attempts permitted when tolerance is exceeded.
;samples: 5 ; Increased from 3 to fix instability. Standard Deviation of 5 samples is more meaningful than 3
mesh_main_direction: x
mesh_runs: 2
speed: 4
contact_max_hotend_temperature: 210 # increase to probe at print temps
home_xy_position: 150, 150 # update with your safe position
home_z_hop: 5
home_z_hop_speed: 10
home_xy_move_speed: 200
home_method: contact # use proximity for induction homing
home_method_when_homed: proximity # after initial calibration use induction
home_autocalibrate: unhomed # contact will calibrate beacon on first home
Hi @dbvanhorn ,
Your log indicates a Y-offset of 0:
[beacon]
serial = /dev/serial/by-id/usb-Beacon_Beacon_RevH_BEC73BF45157355957202020FF0E2E17-if00
x_offset = -18
y_offset = 0 # <---
Can you please upload a klippy.log with the Y offset set to 15 and an attempted bed mesh? Also, why is the x offset set to -18? I assume you have the beacon mounted behind the nozzle on the X-carriage. In that case, I believe X offset should be 0.
Where did you get your mount from? 15mm is puts the nozzle VERY close to the “keep out zone”. your heat block is also a concern.
Hmm. I thought that was the latest log.. That was the value the machine came with, and that’s definitely wrong. It’s now set to X 0 Y 0 so that I could get on with adjusting other things.
So I re-set it to 25, which I believe is the correct value, and uploaded.
klippy.zip (3.0 MB)
The machine was built for me, I don’t know where the mount came from.
See other message, I think 25 is the right number. I was experimenting and 15 was what I had when I decided to ask for help.
Made another discovery, and it looks like this solves it.
When I was looking at the bed mesh, I discovered that the X and Y axis were swapped!
Mesh_main_direction was set to X. I changed it to Y and now the mesh display makes sense. I lifted one side of the sheet with some paper to test, and it shows high on the correct side.
So I went back and set Y offset to 25 again, and no more issues!
Thank you! Even if I did finally dig it out on my own, it’s very useful to have someone knowledgeable to talk to. Just organizing the thoughts to make them presentable frequently leads to the solution. I guess I’m not doing too bad for basically 36 hours experience with Klipper and this whole system.
