Hello,
I have gone to the Discord server a couple of times. I am trying here now.
I have gone through the PROBE and PROBE_CALIBRATE functions so far. Here is the issue. My Z-axis has a probe on it to adjust, home, and use.
Is using a 6v+ or 12v probe functional in Klipper as of today?
My prints use to work. Not so much these days. I have concluded that either my Printer Board is not using the 6v+ on the pins or Klipper is set up in a way that does not handle Probes well enough.
I am not too knowledgeable on Klipper as of now. So, I am reaching out.
# Probe
[probe]
pin: ar100:PH4
z_offset: 0.6267
x_offset: 0.0
y_offset: 0.0
step_pin: ar100:PL6
dir_pin: !ar100:PE10
rotation_distance: 6.35
position_max: 152.4
homing_speed: 5.0
This used to work until an upgrade on the Refactor image on my Recore controller.
Seth
P.S. The probe cannot use the PROBE command or the PROBE_CALIBRATE command any longer b/c of the probe being triggered before those commands. If there was a way to, and I am guessing here, turn the probe off before PROBE and PROBE_CALIBRATE commands, this may prove useful.
Anyway, the Base Layers print awesomely. Then, comes the next layers. They just print on the base layers at the same height as the base layers. Is there any cure?
