Hello!
Tried to follow the guide by @ichbaum , but I get stuck at
‘make -C /usr/src/linux-headers-$(uname -r ) M=$PWD modules’
command returns “no such file or directory” on my side. Is there something I’m missing in there?
Did you restart after updating?
No, I don’t believe I did. I’ll try again tomorrow, thanks!
Tried now but the error text is the same.
pi@fluiddpi:/tmp $ make -C /usr/src/linux-headers-$(uname -r ) M=$PWD modules make: *** /usr/src/linux-headers-5.10.63-v7+: No such file or directory. Stop.
Try cd /usr/src/linux-headers-$(uname -r )
to check if the folder exists.
The git hub download needs to be redone after a reboot. /tmp is erased after each boot.
Downloaded git again, but I get this:
-bash: cd: /usr/src/linux-headers-5.10.63-v7+: No such file or directory
Can you please have a look into /usr/src which Kernel you have?
I’m very new to linux so not quite sure how it’s supposed to look.
Klipper is running so something is right at least
This is from src:
And putty:
Edit: Thanks for taking the time by the way, I appreciate it!
Nothing in /src …
Did you installed the headers?
sudo apt install raspberrypi-kernel-headers
For some reason, that had not happened. That did the trick! Now the screen is at least showing the terminal. Klipperscreen is not running yet.
So, I’m pasting away relentlessly. Like I wrote, I can set the screen to black, random pixels and terminal window but then I run sudo FRAMEBUFFER=/dev/fb1 startx
I get this:
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
And later some of this:
[ 588.706] (WW) Warning, couldn't open module fbdev
[ 588.706] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 588.706] (EE) No drivers available.
[ 588.706] (EE)
Fatal server error:
[ 588.706] (EE) no screens found(EE)
[ 588.706] (EE)
I’m in way above my head here, if you can see anything obvious maybe you can push me in the right direction.
Lost connection with moonraker last night, so had to do a clean install of klipper.
Did everything here again but I get stuck on the same place when running sudo FRAMEBUFFER=/dev/fb1 startx
@ichbaum , I had to add this to the code in order for the screen to start:
sudo apt install xserver-xorg-video-fbdev
Thanks to alfrix on Discord for spotting it.
Maybe the guide should be updated and corrected with your additions too. It is a great little screen!
Sorry for the late answer. Somehow I don’t see the updates on this topic. May be I’m tonold for discord
I will post an update when I’m back at my PC.
I have the fbdev install in my newest script. It wasn’t necessary at first. I think something changed in the raspian version.
#Update system and kernel
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get full-upgrade -y
sudo apt-get clean
sudo apt-get autoremove -y
sudo reboot
#install kernel-headers
sudo reboot
#get vocore
cd /tmp
wget https://github.com/Vonger/vocore2/archive/refs/heads/master.zip
unzip master.zip
cd /tmp/vocore2-master/utils/fbusb/src
#make vocore driver
sudo insmod fbusb.ko
sudo cp fbusb.ko /lib/modules/$(uname -r)/kernel/drivers/
#Load driver at startup
sudo /sbin/depmod -a
#1. set screen to black:
sudo dd if=/dev/zero of=/dev/fb1 bs=1000 count=768
#2. set screen to random pixel:
sudo dd if=/dev/urandom of=/dev/fb1 bs=1000 count=768
#Set Console output to LCD
#add "fbcon=map:10 fbcon=rotate 1" to cmdline.txt
sudo nano /boot/cmdline.txt
#Test console
export FRAMEBUFFER=/dev/fb1
# install xorg driver
sudo apt-get install xserver-xorg-video-fbdev
#https://klipperscreen.readthedocs.io/en/latest/Installation/
#KlipperScreen Installation
cd ~/
git clone https://github.com/jordanruthe/KlipperScreen.git
cd ~/KlipperScreen
./scripts/KlipperScreen-install.sh
#remove fbturbo and use fbdev
sudo rm /usr/share/X11/xorg.conf.d/99-fbturbo.conf
sudo nano /usr/share/X11/xorg.conf.d/99-fbdev.conf
#Add this text ans save
Section "Device"
Identifier "LCD"
Driver "fbdev"
Option "fbdev" "/dev/fb1"
Option "Rotate" "CW"
Option "SwapbuffersWait" "true"
EndSection
#Rotate the touch input too
sudo nano /etc/udev/rules.d/51-touchscreen.rules
#add to file
ACTION=="add", ATTRS{name}=="VoCore Touch", ENV{LIBINPUT_CALIBRATION_MATRIX}="0 1 0 -1 0 1 0 0 1"
#In the KlipperScreen documentation is this metioned to test the touch rotation.
DISPLAY=:0 xinput set-prop "VoCore Touch" 'Coordinate Transformation Matrix' 0 1 0 -1 0 1 0 0 1
#But the /51-touchscreen.rules changes the 'libinput Calibration Matrix' and not 'Coordinate Transformation Matrix'.
#but you can test the 'libinput Calibration Matrix' as well.
DISPLAY=:0 xinput set-prop "VoCore Touch" 'libinput Calibration Matrix' 0 1 0 -1 0 1 0 0 1
