Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
Wanted to install new touchscreen display to use with Klipper screen
Display model [ BTT PI TFT43]
In order to use this display via DSI interface BTT Manta M8P V2 DSI drivers need to be installed
but the issue is that the repository to download set drivers is not longer hosted.
You could try the files from this Waveshare archive ; the link is at the end of the page, under “Demo” : “Source files and demos”. (Waveshare is an official reseller for Raspi’s)
Recently had this issue with two MBs (Manta 5P and Manta 8P), CM4 Lite Compute Modules (not ‘S’), and Waveshare 4.3" DSI touchscreens. Struggled a bit !
The Raspi Foundation removed the drivers ; moreover, the documented command line does not display any error message (404 or whatever) !
I simply copy dt-blob.bin to /boot/ ; the root directory on the FAT partition.
