Printer Model: Tronxy X5SA pro
MCU / Printerboard: MKS Monster 8 V 2 + MKS PI V1.1
klippy.zip (118.1 KB)
Revamping a Tronxy X5SA pro with a MKS monster 8 v2 + mks pi v1.1. I intend to use the stock inductive ABL (blue one).
First time playing with Klipper, seems that everything is wired properly. Klipper configuration checks done, endstops reacting ok, motors going to the right direction, but I couldnt home all so far due to issues Im fixing.
The issue im stuck into is the endstops are ok, connected to the right pins, but the endstop X acts stopping the Y movement and vice versa.
Any idea? Thank you for your support.
In case you want to take a looks at the pins → MKS-Monster8/hardware/MKS Monster8 V2.0_002/MKS Monster8 V2.0_002 PIN.pdf at main · makerbase-mks/MKS-Monster8 · GitHub
