I am not at the computer in the printer room right now but in Cura there is a Printer Settings (or some such) plugin that you can add. With it you can set something like shared heater. Also in multi-extruder cases make sure that the extruder idle temp is the extrusion temp. And I use a gcode find&replace macro to remove M104 T[0-7] S0 but I think that may have been fixed in the current revisions of Cura.
In general I also filter out the Tn Gcodes and use the slicer to insert calls to TOOL_START=Tn and TOOL_END=Tn and use those macros to switch extruders and stuff. Makes it more controllable in Cura, IMHO anyway
craagle
December 4, 2022, 12:23am
24
Hello. There is a printer with 5 extruder motors. I made the settings you gave, but I am getting the following error.
$ ACTIVATE_EXTRUDER EXTRUDER=extruder_stepper extruder3
!! Malformed command ‘ACTIVATE_EXTRUDER EXTRUDER=extruder_stepper extruder3’
am getting this error in extruders that I define as extruder_stepper. There are 2 hotends in my printer. I tried many ways and searched but couldn’t find it. Can you help me?
Sineos
December 4, 2022, 9:00am
25
Try
ACTIVATE_EXTRUDER EXTRUDER="extruder_stepper extruder3"
Sineos
December 4, 2022, 10:31am
27
Key are the " around extruder_stepper extruder3
craagle
December 4, 2022, 10:39am
28
@Sineos
$ ACTIVATE_EXTRUDER EXTRUDER="extruder_stepper extruder3"
!! The value 'extruder_stepper extruder3' is not valid for EXTRUDER
The method you gave did not work. I am sharing my extruder settings.
step_pin:PB5
dir_pin:PB4
enable_pin:!PB6
microsteps:16
rotation_distance: 8.21
;rotation_distance: 23.20 #Bondtech 5mm Drive Gears
;gear_ratio: 48:17
full_steps_per_rotation: 200 #200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.750
min_temp: -250
max_temp: 400
heater_pin: PB1
;sensor_type: NTC 100K MGB18-104F39050L32
;sensor_type: Dyze500
;sensor_type: Generic 3950
sensor_pin: PC1
max_power: 1.0
control : pid
pid_Kp=25.349
pid_Ki=1.760
pid_Kd=91.255
pressure_advance: 0.343
pressure_advance_smooth_time: 0.040
min_extrude_temp: 50
pullup_resistor: 3150
max_extrude_only_accel: 60.0
max_extrude_only_velocity: 60.0
max_extrude_cross_section: 75.0
max_extrude_only_distance: 250.0
[tmc2209 extruder]
uart_pin: PB3
interpolate: True
run_current: 0.65
hold_current: 0.20
sense_resistor: 0.110
stealthchop_threshold: 0
[extruder1]
step_pin: mksruba32: PA0
dir_pin: mksruba32: PC15
enable_pin: !mksruba32: PC11
min_temp: -250
max_temp: 400
heater_pin: mksruba32: PC6
sensor_pin: mksruba32: PC4
max_power: 1.0
control : pid
pid_Kp=25.349
pid_Ki=1.760
pid_Kd=91.255
;pullup_resistor: 3150
[tmc2209 extruder1]
uart_pin: mksruba32: PC14
tx_pin: mksruba32: PA3
interpolate: True
run_current: 0.65
hold_current: 0.20
[extruder_stepper extruder2]
extruder: extruder
step_pin: mksruba32: PE5
dir_pin: mksruba32: PE6
enable_pin: !mksruba32: PE3
microsteps:16
[tmc2209 extruder_stepper extruder2]
uart_pin: mksruba32: PE4
tx_pin: mksruba32: PA4
interpolate: True
run_current: 0.65
hold_current: 0.20
[extruder_stepper extruder3]
extruder: extruder1
step_pin: mksruba32: PE1
dir_pin: mksruba32: PE2
enable_pin: !mksruba32:PB7
microsteps:16
[tmc2209 extruder_stepper extruder3]
uart_pin: mksruba32: PE0
tx_pin: mksruba32: PD13
interpolate: True
run_current: 0.65
hold_current: 0.20
[extruder_stepper extruder4]
extruder: extruder1
step_pin: mksruba32: PB5
dir_pin: mksruba32: PB6
enable_pin: !mksruba32: PC12
microsteps:16
[tmc2209 extruder_stepper extruder4]
uart_pin: mksruba32: PC13
tx_pin: mksruba32: PD14
interpolate: True
run_current: 0.65
hold_current: 0.20
craagle
December 4, 2022, 10:45am
29
@Sineos
The macro I created
Thanks…
[gcode_macro T0]
# Deactivate second extruder stepper
SYNC_EXTRUDER_MOTION EXTRUDER=extruder1 MOTION_QUEUE=
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper extruder2 MOTION_QUEUE=
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper extruder3 MOTION_QUEUE=
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper extruder4 MOTION_QUEUE=
# Activate first extruder stepper
SYNC_EXTRUDER_MOTION EXTRUDER=extruder MOTION_QUEUE=extruder
[gcode_macro T1]
# Deactivate first extruder stepper
# Activate second extruder stepper
SYNC_EXTRUDER_MOTION EXTRUDER=extruder1 MOTION_QUEUE=extruder1
[gcode_macro T2]
SYNC_EXTRUDER_MOTION EXTRUDER="extruder_stepper extruder2" MOTION_QUEUE="extruder_stepper extruder2"
[gcode_macro T3]
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper extruder3 MOTION_QUEUE=extruder_stepper extruder3
[gcode_macro T4]
SYNC_EXTRUDER_MOTION EXTRUDER=extruder_stepper extruder4 MOTION_QUEUE=extruder_stepper extruder4
[gcode_macro ACTIVATE_EXTRUDER]
description: Replaces built-in macro for a X-in, 1-out extruder configuration SuperSlicer fix
rename_existing: ACTIVATE_EXTRUDER_BASE
{% if 'EXTRUDER' in params %}
{% set ext = params.EXTRUDER|default(EXTRUDER) %}
{% if ext == "extruder" %}
{action_respond_info("Extruder")}
T0
{% elif ext == "extruder1" %}
{action_respond_info("Extruder1")}
T1
{% elif ext == "extruder_stepper extruder2" %}
{action_respond_info("Extruder2")}
T2
{% elif ext == "extruder_stepper extruder3" %}
{action_respond_info("Extruder3")}
T3
{% elif ext == "extruder_stepper extruder4" %}
{action_respond_info("Extruder4")}
T4
{% else %}
{action_respond_info("EXTRUDER value being passed.")}
ACTIVATE_EXTRUDER_BASE EXTRUDER={ext}
Sineos
December 4, 2022, 12:10pm
30
Never tried such a setup but generally constructs like above need to be put in "
craagle
December 6, 2022, 9:04pm
31
Blockquote Next, remap the built-in ACTIVATE_EXTRUDER gcode macro so it can be used in your slicer:
{% if ext == "extruder"%}
{action_respond_info("Switching to extruder.")}
T0
{% elif ext == "belted_extruder" %}
{action_respond_info("Switching to belted_extruder.")}
T1
{% else %}
My printer has 2 hotends. One is 2 in 1 out and the other is 3 in 1 out. How should I edit this code? Extruder as follows;
Extruder
Extruder1
belted_extruder2
belted_extruder3
belted_extruder4
I tried a few times but couldn’t find a solution. I edited the motion macro code as follows and it worked, but I couldn’t figure out ACTIVATE_EXTRUDER.
[gcode_macro T0]
# Deactivate stepper in my_extruder_stepper
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder2 MOTION_QUEUE=
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder3 MOTION_QUEUE=
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder4 MOTION_QUEUE=
# Activate stepper in extruder
[gcode_macro T1]
[gcode_macro T2]
# Activate stepper in my_extruder_stepper
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder2 MOTION_QUEUE=extruder
[gcode_macro T3]
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder3 MOTION_QUEUE=extruder1
[gcode_macro T4]
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder4 MOTION_QUEUE=extruder1
@koconnor
jjarosz
December 10, 2022, 1:04am
32
@craagle Did you get your setup working yet?
From the looks of things, you have two “motion system”; Extruder and Extruder1. and you also have three additional belted_extruders.
I didn’t notice, but what belted_extruders are hooked up to which Extruder?
craagle
December 10, 2022, 11:27am
33
Hi @jjarosz
Thank you for your interest. I set up Extruder and belted_extruder2 as the first group, and Extruder1 as belted_extruder 3 and 4 as the second group. Extruder and belted_extruder2 are working now, but I haven’t tried the other group yet.
jjarosz
December 28, 2022, 1:35pm
34
@craagle , sorry for the delay, but here is an example that might fit your printer with:
extruder + belted_extruder2
extruder1 + belted_extruder3 + belted_extruder4
[gcode_macro T0]
descripton: extruder motion system and extruder stepper
[gcode_macro T1]
description: extruder motion system and belted_extruder2 extruder_stepper
[gcode_macro T2]
description: extruder1 motion system and extruder1 stepper
[gcode_macro T3]
description: extruder1 motion system and belted_extruder3 extruder_stepper
[gcode_macro T4]
description: extruder1 motion system and belted_extruder4 extruder_stepper
The description field tells you what stepper and motion system are activated with each T# command.
T0
{% elif ext == "belted_extruder2" %}
{action_respond_info("Switching to belted_extruder2.")}
T1
{action_respond_info("Switching to extruder1.")}
T2
{% elif ext == "belted_extruder3" %}
{action_respond_info("Switching to belted_extruder3.")}
T3
{% elif ext == "belted_extruder4" %}
{action_respond_info("Switching to belted_extruder4.")}
T4
{% else %}
This is an example ACTIVATE_EXTRUDER macro as well.
If you use, please test and advise of your results.
-JJ
craagle
February 5, 2023, 6:54am
35
Hi @jjarosz
I tried the example you gave and I did not get positive results. Since I couldn’t find a solution, I changed my device to a single hotend. At the moment, I am adhering to your solution plan.
I couldn’t use dual hotend with your solution. We need to work for this. Thank you very much for your support.
is there a way to run both extruders at the same time so that material is mixed? like the Marlin m165 gcode, run multiple extruders in relation to each other.
jjarosz
February 6, 2023, 3:01am
37
@SphaeroX it looks like the Dev team may have built the ground work to support mixing extruders, you would have to put it together between macros and slicer config, much like I did with this document.
Check out these two articles:
opened 06:11AM - 02 Dec 18 UTC
closed 01:47PM - 01 Apr 19 UTC
I'm in the process of migrating from Marlin, and would like to use Klipper on my… RepRap Clay printer that uses g-code M163 to divide extrusion between a ram and nozzle. I'm not too great with the tech side (it took me months to get my clay printer going in Marlin and I'd like to try using Kilpper.) I was wondering if anyone would be interested in the same thing ?
<!-- Klipper do something undesirable? YOU MUST ATTACH THE KLIPPER LOG FILE.
See: https://github.com/KevinOConnor/klipper/blob/master/docs/Contact.md -->
Klipper3d:master ← Klipper3d:work-extruder-20220129
opened 01:06AM - 30 Jan 22 UTC
This PR adds a new `SET_EXTRUDER_ROTATION_DISTANCE` command. It supports specif… ying a "negative rotation distance" which will have the effect of reversing the extruder stepper direction. This may be useful for printers with a single extruder motor that can switch between two hotends via a servo.
I do not have a good way to test this PR. Feedback would be appreciated.
This PR is a continuation of PR #5143. This PR also deprecates the `shared_heater` config option, deprecates the `SYNC_STEPPER_TO_EXTRUDER` command, and deprecates the `SET_EXTRUDER_STEP_DISTANCE` command. There are new replacements for all of these features.
This PR was built on top of PR #5209.
@drumclock , @tircown - FYI.
Basically start with what was built in 950 with stepper_extruder module and figure out a way to integrate 5210 SET_EXTRUDER_ROTATION_DISTANCE.
So if I have understood correctly, then I can determine the rotation distance via the GCode. For example, if I had a total of 30, I could say extruder 1: 15 and extruder 2: 15.
So far so good, but how do I get the two to rotate at the same time?
jjarosz
February 6, 2023, 3:31pm
39
You would have to activate two extruder_stepper objects at the same time.
The document I created only has one active at a time.
Then I will probably use Marlin, although I actually always use Klipper. With Marlin you make a GCode and you’re done, stress-free.
M165 A0.2 B0.4 C0.3 D0.1
Hello! I’ve used this config on my Ender 3 Pro, but am encountering an unknown problem where both extruders move at once.
Here is a link to a reddit post I’ve made on the issue
Thank you in advance!
@Xcaldoug I looked at your printer.cfg you posted and there does not seem to to be any config issues. I also checked out your klippy.log file and that looks as if you have more issues that need attention than trying to get the extruder steppers working.
Also, are you using the Creality Sonic Pad by chance? If so, that could be the root cause of your issues. Creality is not using the stock Klipper code and/or the Klipper version might be lower than what is needed for [extruder_stepper] to even work.
Check the top of my post to see the earliest version of Klipper that I have this working under.
Hi, my configuration including macros is here:
MULTI HOTEND
If a hotend of type 2 IN 1 OUT (or xx IN 1 OUT) is used, the filament is automatically replaced outside the printing area.
By default, it is set to the endstop position + 20 mmm. Also tested on IDEX.
The variable for the currently installed filament is saved on the SD card, so that the last configuration is set when the printer is turned on.
The macro is here: MULTI_HOTEND.cfg
This macro is automatically called from the : SETTINGS_TOOL macro
For printers on the IDEX system from the macro: ACTIVATE_CARRIAGE
The macros listed on my Github are universal for configurations
printers for 2 to 4 extruders including dual carriage (IDEX)
This is an example of printer HW configuration for IDEX and 2 IN/1 OUT
# shared heater and sensor HE0 + HE1 and HE2 + HE3
[duplicate_pin_override]
pins: PF6, PB0, PA0, PC5
# ---- carriage X ----
heater_pin: PF6 # HE0
sensor_pin: PB0 # TH0
[extruder1]
heater_pin: PF6 # shared HE
sensor_pin: PB0 # shared TH
# ---- dual carriage ----
[extruder2]
heater_pin: PA0 # HE 2
sensor_pin: PC5 # TH 2
[extruder3]
heater_pin: PA0 # shared HE
sensor_pin: PC5 # shared TH
-Petr
