X moving while doing PROBE_CALIBRATE
Printer Model: CR10 V2
MCU / Printerboard: SKR 1,4 Turbo, TCVM2209, BIQU H2 extruder
Host / SBC: Raspberry pi 4 4GB
klippy.log (117.9 KB)
Hi all, still working through my first Klipper install.
When running PROBE_CALIBRATE is it normal for it to spend about 30 seconds slowly moving in the X direction? It moves slowly to the right before eventually stopping.
Please see attached vid to see what I mean
https://youtu.be/Vo1HOXvDkEc
This command will move the nozzle over the probed spot so that you can set the Z-offset. The default speed is 5 mm/s.
