Printer Model: No-name (cartesian, IDEX)
MCU / Printerboard: no-name w/Atmega256 & TMC2209
Host / SBC: RPi Zero 2W
klippy.log: not available
The printer
I am trying to understand the kinematic model and proper configuration for the Z-axis values. The printer physically has 2 lead screws, 2 z-steppers, and 2 IR sensors on Z that trigger with head below the bed. The printer doesn’t have nozzle probe.
The problem
From what I put together it seems to be unusual to have
I think I am having two compounding issues here:
- I am not fully understanding how “position_min” and “position_endstop” are used.
- My Z limit sensor is below the bed, which is apparently unusual (?)
My understanding so far
position_min&position_endstopmake complete sense to me for X & Y after reading @Sineos Understanding X and Y Axes Limits and Homing guide. In essence for X & Y they have some negative values so Klipper knows where (0,0) is. However, I cannot wrap my head around Z axis.- In my understanding
position_minis the physical gantry limit. If I understand this correctly, this makes it almost an arbitrary number on Z, i.e. default0mmis fine. - The
position_endstopis confusing to me. The documentation offers no help saying thatposition_endstopis “Location of the endstop” which doesn’t help
- If I apply the same logic as for X/Y and set it
position_minandposition_endstopto be equal and negative by the difference between physical endstop triggering and nozzle passing the paper test it will work. However, this means that the nozzle can still easily crash into the bed. - In my head, esp. after looking at
Z_ENDSTOP_CALIBRATE& bed leveling guide, I would imagineposition_minbeing the bed level withposition_endstop<position_minto represent endstop being below the bed. However, such configuration is invalid. - Based on FAQ entry “Why is the Z position_endstop set to 0.5 in the default configs” (cannot link as a new user) it is almost implied that physical Z endstop should never be below the bed?
- I can set
position_minandposition_endstopto 0 and useSET_GCODE_OFFSET Z=#after homing with a value that is a difference between endstop and top surface of the bed… but this doesn’t feel right.
What am I understanding wrong here? This seems like it should be a pretty easy setting to derive but it is giving me a headache for hours ![]()
