Can't moving z axis under 0
klippy.log (1.5 MB)
Issue:
When I move the axis, using a bedmesh generated by a bltouch, klipper says: “the Z doesn’t go under 0”.
How I can resolve this?
Set a negative position_min for your z-stepper.
I tried this solution, but klipper, if there is it, doesn’t use generated bedmesh.
What’s about Klipper generating a new mesh?
I already tried.
You are missing
position_min:
in stepper_z.
step_pin = PC13
dir_pin = !PF0
enable_pin = !PF1
microsteps = 8
rotation_distance = 8
position_max = 400
Set it to a negative value. Something like -3 to start with.
If that line is absent, Klipper takes 0 for position_min:
https://www.klipper3d.org/Config_Reference.html#stepper
