Z-offset problem
Printer Model: voron 2.4R
MCU / Printerboard:Octopus
…I haven’t been able to get my required z_offset to apply.
My [probe] section is correct, according to the guides:
If I start a print, the nozzle is too high (~0.2mm)
I use the “z_offset” buttons in mainsail front-end to adjust my z-offset.
The nozzle lowers to the requested height, and the print continues.
I use the “SAVE” button to save the z_offset.
A popup tells me to use the SAVE_CONFIG option to save the z_offset to the config file, and restarts the printer.
I send the SAVE_CONFIG command.
The [probe] section in the “do not edit” section of the config file, updates with the proper z_offset that was saved earlier.
On the next print, the nozzle is AGAIN too high.
I adjust it back down another 0.200mm to correct the height.
The [probe] section in the “do not edit” area updates correctly AGAIN.
Next print, nozzle too high!
I can repeat this process, over and over again.
The new z-offset never seems to actually apply.
Can anyone explain this?
Printer.cfg renamed to printer.log in order to get it uploaded same with start.cfg
Thanks
klippy-2.log (841.0 KB)
printer.cfg (18.5 KB)
start.log (1.7 KB)
Have you tried with a pristine Klipper setup?
Git version: 'v0.13.0-452-g8dd798ebb-dirty'
Untracked files: klippy/extras/bed_thermal_adjust.py, klippy/extras/manual_rail.py, klippy/extras/multi_fan.py, klippy/extras/rounded_path.py, klippy/extras/tool.py, klippy/extras/tool_probe.py, klippy/extras/tool_probe_endstop.py, klippy/extras/toolchanger.py, klippy/extras/tools_calibrate.py
There maybe is an addon that can conflict with the offset setting: The "dirty" Flag and the Team's Position
I am not sure what you mean ?
Pristine in this case means a Klipper setup without addons.
sorry for my dumb questions, but to my knowledge I don’t have any add ons ?
They are in line no. 2 of my first post:
Please read this post:
Toolchanger
Toolchanger Offsets - Try here
Those files are part of the “klipper-toolchnager” addon. From your config and klippy, you do not have a toolchanger… They should not affect the working of the probe section. But a new install would be good. Other things may still be there.
Is you klippy.log edited? your printer.cfg has an include for a start.cfg, that is not in the klippy.log
Update klipper. allot of changes where made from “v0.13.0-452” on how probes work.
the log is not edited.
Will try an update, to see if this helps, and remove the tool changer parts
Updated klipper, same problem, new log and cfg attached
start.cfg (1 KB)
printer.cfg (18.4 KB)
klippy-3.log (82.9 KB)
How did you determined the z-offset before print? Try doing the z-offset before printing.
I presume you use TAP. I see you load the mesh when printing. Try not loading, but doing an adaptive mesh when printing.
I had exactly the same problem and the issue was a conflict off offsets with the probing and the nozzle tip.
On a typical Voron 2.4, the Z-offset is managed by the physical Z endstop (the “clicky” switch), not by the probe’s z_offset in the [probe] section. The probe’s offset should be zero, and the correct value is applied via the position_endstop in the [stepper_z] section.
When saving offsets I get two choices:
· “Save Z Endstop” – applies the offset to the physical Z endstop (the position_endstop in [stepper_z]).
· “Save Z Probe” – applies the offset to the probe’s z_offset in the [probe] section
You should only select Z endstop and ensure the other value is set to zero.
Aim for something like this:
## DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
# [stepper_z]
## position_endstop = 0.814
# [probe]
#*# z_offset = 0
