Z offset not saving!
Printer Model: Voron v2.4r2
MCU / Printerboard:Octopus v1.2
Host / SBC rpi4b
klippy.log (8.0 MB)
…I recently changed my probe from the one Omron probe to a Cartographer 3d probe. It all seems to work correctly except that when setting the z offset( by Z_OFFSET_APPLY_PROBE command then save_config. After the restart it seems to revert back to the previous settings/height?
Any advice would be much appreciated!
Post your printer.cfg as well, please. Attach it, not copy and paste.
printer.cfg (30.2 KB)
Please find my printer.cfg attached. Thank you
Your printer.cfg:
grafik
Your log:
Seems everything is as it should be.
I had another look at the printer.cfg and in the ‘stepper_z’ section I noticed that the ‘position_min’ was set at -2.5, so I’m assuming that if the z offset was set lower than this eg. -2.54 then it would not go lower than the -2.5?
True, AFAIK, this most be higher to work correctly.
