Z-offset saving Problem
Hello.
I have installed Klipper on Kobra 2.
The only Problem what i have, it dosn´t save the z-Offset in the Printerconfig. What can i do to fix this Problem.
Greetz Daniel
Could you please fill out the information that was requested when you make the original post:
I have the same problem using the z-offset section. Try going to the console and entering probe_calibrate
The same applies to you as @mykepredko mentioned to the OP.
But not to you?
I’m not reporting an issue here?
My apologies if I came across as reporting an issue. I was reporting how I was able to set my z-offset. Since probe_calibrate works I assume it a mainsail issue not a zipper one.
