Printer Model: coreXY with 3 Z-steppers
MCU / Printerboard: SKR pro
after checking all klipper documentations I could not find an answer to this simple (?) question:
Z_tilt_adjust is working fine together with BLtouch. But: The printer is loosing the z_adjustments after homing. I’d like to store this Z adjustments so that they will be added to each z-axis for every print job.
→ I have good accuracy optical endstops on all 3 z-axis. The reference is fine. It is just somehow hard to finde the perfect adjustments for echa axis manually. Z_tilt_adjust is ideal for that, but I dont see how to make this adjustment permanent.
Thank you for any hints, maybe I am just missing something
regards
Andy
Standard x,y,z machine. My understanding is the z tilt levels the x axis and is done. There isn’t anything to save. The abl will correct for any small error.
Saving the values makes no sense because the positions of the 2(,3 or 4) Z steppers can differ too much after shutting power off. Micro-stepping for adjustment and jumping back to full step after power off.
@ manac
Sorry, I didn’t get the point. Z tilt is adjusting independent multiple z axis motors.
@EddyMI3D
My setup has an endstop on all 3 z axis. So, g28 will bring all 3 z axis to a well defined position. But I would have to fine adjust each z axis to get the bed perfect leveled. This fine adjustment could be calculated once by z tilt and this values could be added to each z axis again after g28
Edit:I would also store that manually but I am not sure where I could store offsets for each single z axis
This will be different every time. Believe me. You can not get 100% the same position every homing. It’s about 0.01 of a millimeter. That can be changed by ambient temperature and other things.
If it would work like you say, Z_TILT_ADJUST would be obsolete.
hi,
to be honest: My bed warpage is far away from beeing below 0.01mm but practically good. (what I want to say with that: endstop accuracy of ±0.01 is totally fine for me but could maybe even improved with endstop phase implementation)
What I am currently doing successfully is adjusting the 3 z endstops so that my bed is leveled (bringing nozzle near the related z axis and level with a feeler gauge). But z tilt adjust can middle the complete bed and can find a compromise over the complete bed.
Z tilt is adjusting the z axis ~z -0.05, z1 -0.07, z2 +0.02 (by the way very consistently each time)
Now I have 2 possibilities:
My current workaround plan is to note each z adjustment and adjust each endstop manually as they can be adjusted with a M3 screw
Store the z adjustments as z, z1, z2 offset and add them to the axis after homing.
Option 2 would be more elegant as it could be done from time to time more easily (for example if something has to be changed on the bed)
I’m not sure I understand what is being asked here, so my response below may not help much.
If you have 3 z motors each with their own endstops, and you know an adjustment needs to be made after homing to those endstops, then you can use the Z_TILT_ADJUST tool to determine the adjustments necessary. If you know that the printer will always make the same adjustment to the Z on every Z_TILT_ADJUST (or, just wish to force it to make the same adjustment) then you can use the FORCE_MOVE command to forcibly alter each Z stepper motor by a static amount. So, for example, one could use the GET_POSITION command before and after a Z_TILT_ADJUST command to determine the actual stepper adjustments made to each Z stepper, and then use macros to make the equivalent FORCE_MOVE adjustments after every G28 command.
There is no automated tool to make these static adjustments. See the important warnings in the documentation on using FORCE_MOVE (in short, if it is used incorrectly it can cause all sorts of problems).
yes you have the correct understanding of the “issue”
This “force move” makro is a very good workaround idea. Thanks for that, I will implement this together with a “stepper phase endstop” and I am pretty sure that I get good and consistent results.
Thanks Kevin
btw. This is the printer with the two xycore heads on two independent gantries (our 2 software guys are still trying to establish a good custom klipper branch )
