I’m looking at possibly replacing my bed carriage with a Gulf Coast Robotics 3 point carriage. Currently Klipper does 4 point Screw Tilt Adjust and I was wondering if its possible to setup 3 point screw tilt adjust?
Even today, only 2 screws are required. See https://www.klipper3d.org/Config_Reference.html#screws_tilt_adjust
simple answer is Yes
did you just want help leveling it? or were you going to do bed_tilt_calibrate as well?
Thank you for the info. I just assumed you needed 4 screw locations. This is great news.
oh and one thing, if you use klipperscreen… it will support 3 screws but not by default, and will have to be configured in klipperscreen.conf
