3d touch sensor blinks when triggered
Printer Model: vz bot
MCU / Printerboard:lpc1768
lpc1768
Version: v0.12.0-175-g7b490f3e
aarch64, 64bit
Version: v0.12.0-286-g81de9a861
OS: Debian GNU/Linux 11 (bullseye)
Distro: MainsailOS 1.3.2 (bullseye)
klippy.log (5.1 MB)
printer.cfg (5.0 KB)
BTT skr ver 1.4
I try to get a 3d touch to work. But the moment I trigger it it starts blinking and goes in to error mode. I freshly installed the probe and connected it to my SKR v1.4 board.
Then I added the line in printer.cfg
[bltouch]
sensor_pin: ^P0.10 #Probe
control_pin: P2.0 #SERVOS
x_offset: 37.10
y_offset: 9.25
z_offset: 0.00
When I run the initial test from BL-Touch - Klipper documentation
Everything works as expected until the part where I should test the trigger. The moment I try to trigger it pulls back it starts flashing blue and red. After reset it works normally except the trigger doesn’t work. one odd thing I experienced further was when included the [safe_z_home] part the the z axis moved down further and further instead of up for homing.
For the 3Dtouch is not a genuine BLtouch, you may have a look on this:
https://www.klipper3d.org/BLTouch.html#bl-touch-clones
did you check (double-check) your wiring? Wiring corresponds with settings?
Yes triple checked wiring. Especially because sensor servo works with up down movement
Yes but didn’t solved it
Ok I found a solution. Folowing this Blog post. Just tried different combinations of:
stow_on_each_sample: False/True
probe_with_touch_mode: False/True
pin_up_reports_not_triggered: False/True
pin_up_touch_mode_reports_triggered: False/True
For me True/False/True/False worked
