Anycubic Kobra Max config file
what was the settings you used to create this file?
what do you mean by
I was building the firmware.bin file myself, per the klipper install instructions and details noted at the top of printer-anycubic-kobra-plus-2022.cfg.
Ref:
https://www.klipper3d.org/Installation.html#building-and-flashing-the-micro-controller
The configuration in the notes of the cfg file noted the micro-controller and communication interface to select when running make menuconfig, but not anything else (such as the ‘Clock Speed’. So I kept everything else the default. This set a clock speed of ‘168 MHz’.
This was giving me the Timer too close error I noted when homing, and in digging around I noticed that the Mainsail interface showed the MCU had a freq of 200 Mhz. So I re-built the firmware.bin setting the ‘Clock Speed’ to match that, and that fixed the timer error.
That said, I’ve also begun getting the OvertempWarning! on stepper_z now too…
So I figured out that the problem with OvertempWarning! seems to be that the fan controlling the MCU board is tied to the heater bed temp in the default config.
[heater_fan controller_fan]
pin: PA14
heater: heater_bed
heater_temp: 45.0
So the fan cooling the control board would only kick on if the bed was at 45+. For me, this explains why I was only encountering OvertempWarning! when I wasn’t printing but the stepper motors were still on (so idle, basically).
On some other’s advice I replaced that section of the config with this.
[controller_fan electronics]
pin: PA14
heater: heater_bed, extruder
shutdown_speed: 0.0
And haven’t had an issue now.
did you solve the leveling problem? I have the same problem
i cannot get the .bin file to work it just stays on the anycubic logo
orry if this question has already been answered, where can I find a step-by-step video on how to configure the sonic pad on the kobra max.
SAme here stuck…
You are a hero mate. This file saved me. was stuck on line 21 error. Cheers ! beers on me
I have new board where the resistor is in the correct spot. I used your .bin file but still can’t connect any help? I am using the pad7.
I have never used a pad 7. Does it see your printer? I used lsusb, ls /dev/serial/by-path/*, etc to find the mcu by SSH into the Pi.
I am getting msu error currently
I can get the ID but after that it won’t work
What ID do you receive and what MCU errors do you get?
The same one that is in the configuration file. And picture for error.
did the same changes, but i do have a newer board, any ideas why it did not work
Did you enter the mcu in the printer.cfg?
Yes, I can try again
how do you know the baud rate?
serial: /dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0
restart_method: command
#baud: 250000
baud rate is 250000 but I left it commented out.
platform-5200000.ehci1-controller-usb-0:1.3:1.0-port0
