Artillery sidewinder x1 problem with printer config?
Printer Model: Artillery Sidewinder x1
MCU / Printerboard: Original MKS Gen L v1.0, BLTouch Waggster mod
klippy.log (1.1 MB)
…Having a disaster of a time getting Klipper set up on my Sidewinder X1. Have tried multiple config files and adjusted parameters and still printer head begins to violently shake back and forth on X axis with a loud grinding noise when home button is pressed. Unable to get the toolhead controls functional other than home buttons. Any help is appreciated since I am just trying out klipper and failing miserably! Thank you in advance for your time and help!
Hello @dvm2003 !
Check if the endstops are assigned to the correct pins:
https://www.klipper3d.org/Config_checks.html#verify-endstops
In all, you may walk through all the points:
I did check the endstops and they seemed to be working fine. I checked the stepper motors and the extruder motor. Thanks for trying to help!
There is this in the logs:
No trigger on x after full movement
Check if the endstop can be triggered by the printhead.
Does the printhead move towards the printhead when homing.
