BED_MESH_CALIBRATE with PROBE_COUNT=xxx help
Hi All,
I am trying to work out how to include the ‘probe count=’ parameter, with no luck.
Have tried
BED_MESH_CALIBRATE MESH_MIN={XMIN-5},{YMIN-5} MESH_MAX={XMAX+5},{YMAX+5} PROBE_COUNT=3
and
BED_MESH_CALIBRATE MESH_MIN={XMIN-5},{YMIN-5} MESH_MAX={XMAX+5},{YMAX+5} PROBE_COUNT=3,3
ERROR
12:33:04
!! Malformed command 'BED_MESH_CALIBRATE MESH_MIN=119,119 MESH_MAX=140,140 PROBE_COUNT= 3,3'
Thanks
Have you tried defining it in printer.cfg?
probe_count: 3,3
Hi gabe.mi,
I have worked out how to probe only the printed objects area, and not the full bed. Works well.
But when the object is less than 100x100 I need it to probe 3,3 as 5,5 is way overkill for small objects.
At the mo I just leave it at 5,5, but would be nice to do 3,3 programmatically base on object size.
I have it defined as 5,5 in printer.cfg.
Thanks
See Klipper bed mesh on print area only macro install guide · GitHub
Thanks, I didnt know this existed, so tried to do it myself…
