Printer Model: creality K1 max
MCU / Printerboard:
Fill out above information and in all cases attach your klippy.log
file (use zip to compress it, if too big). Pasting your printer.cfg
is not needed
… Hi everyone, I’m new to all this so I apologise in advanced if I have done something wrong on here. I have rooted my creality K1 max and with limited experience in coding I am trying to increase the probe count from 6,6 to 10,10 with bicubic interpolation as I have lots of bed warping at high temps. In doing so I get the following error :
!! {“code”:“key60”, “msg”:“Internal error on command:_BED_MESH_CALIBRATE”, “values”: [“_BED_MESH_CALIBRATE”]}
It occurs at probe 36 which makes me think somewhere in the c++ there is a max index value for lists of 36. Any Ideas would be appreciated thanks :))
