Bltouch not changing status
Hello,
Klipper log here: ===== Config file =====[duplicate_pin_override]pins = ar9, ar10, analog13 - Pastebin.com
I cant seem to get the bltouch (Creality BLTouch V3.1) to change state from opened to triggered. It stays in one state no matter where the pin is. It seems to do its initial testing when I turn on the system just fine. Attached is the log of me trying to perform the inital tests from the klipper website regarding BLtouch.
I have tried changing the pin destinations for the endstop and the sensor pin, thinking my board may be defective, but they did not help. I am using an MKS gen l (https://www.amazon.com/dp/B07KCBLXK1?psc=1&ref=ppx_yo2ov_dt_b_product_details)
Any additional ideas on troubleshooting or perhaps any ideas where the issue may be arising (coding, wiring etc…)?
Thank you!
Please upload a picture to see if the cable connections are correct.
Does the pin work with the pin up/down command in “Initial tests”?
https://www.klipper3d.org/BLTouch.html
