Btt Relay 1.2 klipper config
Printer Model: Flsun SR
MCU / Printerboard: BTT manta M8P with EBB42
Host / Klipper
Hello everyone needeed help, I have Btt relay 1.2 with Klipper and Motherboard Bigtreetech Manta M8P V2
recently installed relay and not find config for klipper, needeed config plase for add in my printer.cfg
Thanks
See BTT Relay V1.2 with SKR Mini E3 V3.0 - shuts down before Klipper loads - #9 by Sineos
(on a sidenote: using the search function here does not hurt. I promise, tried it myself)
Needeed arquive for copy in my printer
Ese no sirve necesito el archivo para copiar en mi primer.cfg todo el código ese no funciona da error
It doesn’t work that way. You have to add the specific lines to your cfg file depending on how you connected your relay, which controller board pin you are using, and what you want the relay to control.
Uso pin PS-ON y quiero que cuando acabe de imprimir se apague la impresora, no tengo codigo
According to the BTT pinout, that is pin PD14. The rest of the instructions in the thread @Sineos linked should apply to your situation.
Ok is PD14 but what config use? Actually in my printer.cfg no have config for relay, please help me
You have to add it yourself. @Sineos already provided a link to a thread giving step-by-step instructions: BTT Relay V1.2 with SKR Mini E3 V3.0 - shuts down before Klipper loads
