Can not start the screen
it shown this error…
2023-11-12 08:44:46,398 [config.py:init()] - Unknown error with the config:
Source contains parsing errors: ‘’
[line 69]: ‘printer.bltouch # Available if bltouch section defined in config\n’
[line 70]: ‘printer.gcode_macros.count # Number of gcode macros\n’
[line 71]: ‘printer.idle_timeout # Idle timeout section\n’
[line 72]: ‘printer.pause_resume # Pause resume section of Klipper\n’
[line 73]: ‘printer.probe # Available if probe section defined in config\n’
[line 74]: ‘printer.power_devices.count # Number of power devices configured in Moonraker\n’
What can i recheck it?
As reported your config is wrong and this prevents a proper start.
Would help if you upload your printer.cfg.
This is a config …
deleted, please attach - Sineos
Ever thought to upload the printer.cfg as file or at least format it as preformatted text?
Format
# This file contains common pin mappings for the BigTreeTech OctoPus V1.
# To use this config, the firmware should be compiled for the STM32F446 with a "32KiB bootloader"
# Enable "extra low-level configuration options" and select the "12MHz crystal" as clock reference
# after running "make", copy the generated "klipper/out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the OctoPus with that SD card.
## Voron Design VORON2 250/300/350mm BigTreeTech OctoPus V1 TMC2209 UART config
## *** THINGS TO CHANGE/CHECK: ***
## MCU paths							[mcu] section
## Thermistor types						[extruder] and [heater_bed] sections - See 'sensor types' list at end of file
## Z Endstop Switch location			[safe_z_home] section
## Homing end position				[gcode_macro G32] section
## Z Endstop Switch  offset for Z0		[stepper_z] section
## Probe points							[quad_gantry_level] section
## Min & Max gantry corner postions		[quad_gantry_level] section
## PID tune								[extruder] and [heater_bed] sections
## Probe pin								[probe] section
## Fine tune E steps					[extruder] section
[virtual_sdcard]
path: ~/printer_data/gcodes
[display_status]
[pause_resume]
[display_status]
[pause_resume]
##	[X in MOTOR0] - B Motor
##	[Y in MOTOR1] - A Motor
##	[E in MOTOR6] - Extruder
##	Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_2D0023000550534E4E313020-if00
#restart_method: command
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000    			#Max 4000
max_z_velocity: 15 			#Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
# 	X/Y Stepper Settings
## X Stepper on MOTOR0(B Motor)
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
rotation_distance: 40
full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
endstop_pin: PG6
position_min: 0
##	Uncomment below for 250mm build
#position_endstop: 250
#position_max: 250
##	Uncomment for 300mm build
#position_endstop: 300
#position_max: 300
##	Uncomment for 350mm build
position_endstop: 350
position_max: 350
homing_speed: 100  #Max 100
homing_retract_dist: 5
homing_positive_dir: true
##	Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: True
run_current: 0.7
hold_current: 0.7
sense_resistor: 0.110
stealthchop_threshold: 0
## Y Stepper on MOTOR1 (A Motor)
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
endstop_pin: PG9
position_min: 0
##	Uncomment for 250mm build
#position_max: 250
#position_max: 300
position_max: 350
homing_speed: 75  #Max 100
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: True
run_current: 0.8
hold_current: 0.7
# 	Z Stepper Settings
## Z0 Stepper - Front Left on MOTOR2_1
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
endstop_pin: PG10
##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
##  (+) value = endstop above Z0, (-) value = endstop below
##	Increasing position_endstop brings nozzle closer to the bed
##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
#position_endstop: -0.5
#position_max: 240
##	Uncomment below for 300mm build
#position_max: 290
##	Uncomment below for 350mm build
position_max: 340
position_min: -15
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: true
run_current: 0.8
hold_current: 0.8
##	Z1 Stepper - Rear Left on MOTOR3
[stepper_z1]
step_pin: PG4
dir_pin: !PC1
enable_pin: !PA0
gear_ratio: 80:16
[tmc2209 stepper_z1]
uart_pin: PC7
interpolate: true
run_current: 0.8
hold_current: 0.8
##	Z2 Stepper - Rear Right on MOTOR4
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
gear_ratio: 80:16
[tmc2209 stepper_z2]
uart_pin: PF2
interpolate: true
run_current: 0.8
hold_current: 0.80
##	Z3 Stepper - Front Right on MOTOR5
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
enable_pin: !PF1
gear_ratio: 80:16
[tmc2209 stepper_z3]
uart_pin: PE4
interpolate: true
run_current: 0.8
hold_current: 0.80
# 	Extruder
#	E0 on MOTOR6
step_pin: PE2
dir_pin: !PE3
enable_pin: !PD4
##	Update value below when you perform extruder calibration
##	If you ask for 100mm of filament, but in reality it is 98mm:
##	rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
##  22.6789511 is a good starting point
#rotation_distance: 22.6789511	#Bondtech 5mm Drive Gears
rotation_distance:35.65692
##	Update Gear Ratio depending on your Extruder Type
##	Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
##	Use 80:20 for M4, M3.1
#gear_ratio: 50:17				#BMG Gear Ratio
gear_ratio: 7.5:1
full_steps_per_rotation: 200	#200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.75
heater_pin: PA2
##	Validate the following thermistor type to make sure it is correct
#sensor_type: ATC Semitec 104GT-2
sensor_type: T_D500
sensor_pin: PF4
min_temp: 10
max_temp: 500
max_power: 1.0
min_extrude_temp: 205
control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
#pid_kp: 14
#pid_ki: 0.5
#pid_kd: 125
pid_Kp: 22.808
pid_Ki: 1.462
pid_Kd: 88.951
##	Try to keep pressure_advance below 1.0
pressure_advance: 0.05
##	Default is 0.040, leave stock
pressure_advance_smooth_time: 0.040
##	E0 on MOTOR6
[tmc2209 extruder]
uart_pin: PE1
interpolate: false
run_current:  0.5
hold_current: 0.2
# 	Bed Heater
[heater_bed]
##	SSR Pin - BED_OUT
heater_pin: PA1
sensor_type: NTC 100K beta 3950
sensor_pin: PF3
##	Adjust Max Power so your heater doesn't warp your bed
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
# 	Probe
[probe]
##	Inductive Probe
##	This probe is not used for Z height, only Quad Gantry Leveling
# Select the probe port by type:
## For the PROBE port; use this with the original OMRON sensor.
pin: ~!PB7
## For the spare endstop port; use this with the Fotek PL-05N (or generic) inductive probe
#pin: ^PG11
## For Octopus Pro Probe port; NPN and PNP proximity switch types can be set by jumper
#pin: ^PC5
x_offset: 0
y_offset: 25.0
#z_offset: 0
speed: 10.0
samples: 1
samples_result: median
sample_retract_dist: 10
samples_tolerance: 0.006
samples_tolerance_retries: 1
# 	Fan Control
[fan]
##	Print Cooling Fan - CNC_FAN0
pin: PA8
kick_start_time: 0.5
##	Depending on your fan, you may need to increase this value
##	if your fan will not start. Can change cycle_time (increase)
##	if your fan is not able to slow down effectively
off_below: 0.10
[heater_fan hotend_fan]
##	Hotend Fan - CNC_FAN1
pin: PE5
max_power: 1.0
heater: extruder
heater_temp: 50.0
##	If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
[heater_fan controller_fan]
##	Controller fan - CNC_FAN2
pin: PD12
heater: heater_bed
heater_temp: 45.0
[heater_fan exhaust_fan]
##	Exhaust fan - CNC_FAN3
pin: PD13
max_power: 1.0
shutdown_speed: 0.0
kick_start_time: 5.0
heater: heater_bed
heater_temp: 60
fan_speed: 0.25
# 	LED Control
#[output_pin caselight]
# Chamber Lighting - HE1 Connector (Optional)
#pin: PA3
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
# 	Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
##	XY Location of the Z Endstop Switch
##	Update -10,-10 to the XY coordinates of your endstop pin
##	(such as 157,305) after going through Z Endstop Pin
##	Location Definition step.
home_xy_position:264,350
speed:100
z_hop:10
[quad_gantry_level]
##	Use QUAD_GANTRY_LEVEL to level a gantry.
##	Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##	MAX (250, 250), (300,300), or (350,350) depending on your printer size
##	to respective belt positions
##	Gantry Corners for 250mm Build
#gantry_corners:
#	-60,-10
#	310, 320
##	Probe points
#points:
#	50,25
#	50,175
#	200,175
#	200,25
##	Gantry Corners for 300mm Build
#gantry_corners:
#	-60,-10
#	360,370
##	Probe points
#points:
#	50,25
#	50,225
#	250,225
#	250,25
##	Gantry Corners for 350mm Build
gantry_corners:
	-60,-10
	410,420
##	Probe points
	50,25
	50,275
	300,275
	300,25
speed: 1000
horizontal_move_z: 19
retries: 4
retry_tolerance: 0.05
max_adjust: 20
# EXP1 / EXP2 (display) pins
[board_pins]
aliases:
    # EXP1 header
    EXP1_1=PE8, EXP1_2=PE7,
    EXP1_3=PE9, EXP1_4=PE10,
    EXP1_5=PE12, EXP1_6=PE13,    # Slot in the socket on this side
    EXP1_7=PE14, EXP1_8=PE15,
    EXP1_9=<GND>, EXP1_10=<5V>,
    # EXP2 header
    EXP2_1=PA6, EXP2_2=PA5,
    EXP2_3=PB1, EXP2_4=PA4,
    EXP2_5=PB2, EXP2_6=PA7,      # Slot in the socket on this side
    EXP2_7=PC15, EXP2_8=<RST>,
    EXP2_9=<GND>, EXP2_10=<5V>
# 	Displays
## 	Uncomment the display that you have
#[display]
##	RepRapDiscount 128x64 Full Graphic Smart Controller
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#encoder_pins: ^EXP2_5, ^EXP2_3
#click_pin: ^!EXP1_2
#[output_pin beeper]
#pin: EXP1_1
[display]
##	mini12864 LCD Display
lcd_type: uc1701
cs_pin: EXP1_3
a0_pin: EXP1_4
rst_pin: EXP1_5
click_pin: ^!EXP1_2
contrast: 63
spi_software_miso_pin: EXP2_1
spi_software_mosi_pin: EXP2_6
spi_software_sclk_pin: EXP2_2
[neopixel btt_mini12864]
##	To control Neopixel RGB in mini12864 display
pin: EXP1_6
chain_count: 3
initial_RED: 0.1
initial_GREEN: 0.5
initial_BLUE: 0.0
color_order: RGB
##	Set RGB values on boot up for each Neopixel.
##	Index 1 = display, Index 2 and 3 = Knob
[delayed_gcode setdisplayneopixel]
initial_duration: 1
        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=1 TRANSMIT=0
        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
# 	Macros
[bed_mesh]
speed: 120
mesh_min: 30,30
mesh_max: 340,340
probe_count: 6,6
[gcode_macro G32]
    BED_MESH_CLEAR
    G28
    QUAD_GANTRY_LEVEL
    G28
    ##	Uncomment for for your size printer:
    #G0 X125 Y125 Z30 F3600
    ##	Uncomment for 300 build
    #G0 X150 Y150 Z30 F3600
    G0 X175 Y175 Z19 F3600
[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
    G32                            ; home all axes
    G1 Z10 F3000                   ; move nozzle away from bed
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-10.0 F3600                ; retract filament
    G91                            ; relative positioning
    G0 Z1.00 X20.0 Y20.0 F20000    ; move nozzle to remove stringing
    TURN_OFF_HEATERS
    M107                           ; turn off fan
    G1 Z2 F3000                    ; move nozzle up 2mm
    G90                            ; absolute positioning
    G0  X125 Y250 F3600            ; park nozzle at rear
    BED_MESH_CLEAR
[gcode_macro PAUSE]
description: Pause the actual running print
rename_existing: PAUSE_BASE
    ##### set defaults #####
    {% set x = params.X|default(230) %}      #edit to your park position
    {% set y = params.Y|default(230) %}      #edit to your park position
    {% set z = params.Z|default(50)|float %} #edit to your park position
    {% set e = params.E|default(1) %}        #edit to your retract length
    ##### calculate save lift position #####
    {% set max_z = printer.toolhead.axis_maximum.z|float %}
    {% set act_z = printer.toolhead.position.z|float %}
    {% set lift_z = z|abs %}
    {% if act_z < (max_z - lift_z) %}
        {% set z_safe = lift_z %}
    {% else %}
        {% set z_safe = max_z - act_z %}
    ##### end of definitions #####
    PAUSE_BASE
    G91
    {% if printer.extruder.can_extrude|lower == 'true' %}
      G1 E-{e} F2100
    {% else %}
      {action_respond_info("Extruder not hot enough")}
    {% if "xyz" in printer.toolhead.homed_axes %}
      G1 Z{z_safe}
      G90
      G1 X{x} Y{y} F6000
    {% else %}
      {action_respond_info("Printer not homed")}
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
    #### get VELOCITY parameter if specified ####
    {% if 'VELOCITY' in params|upper %}
      {% set get_params = ('VELOCITY=' + params.VELOCITY)  %}
    {%else %}
      {% set get_params = "" %}
    G91
      G1 E{e} F2100
    {% else %}
    RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
    TURN_OFF_HEATERS
    CANCEL_PRINT_BASE
# printer.cfg
[include timelapse.cfg]
[thermistor T_D500]
temperature1: 210
resistance1: 6337
temperature2: 270
resistance2: 1846
temperature3: 330
resistance3: 684.2
## 	Thermistor Types
##   "EPCOS 100K B57560G104F"
##   "ATC Semitec 104GT-2"
##   "NTC 100K beta 3950"
##   "Honeywell 100K 135-104LAG-J01"
##   "NTC 100K MGB18-104F39050L32" (Keenovo Heater Pad)
##   "AD595"
##   "PT100 INA826"
#*# [stepper_z]
#*# position_endstop = -2.350
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	9.690000, 9.735000, 9.792500, 9.820000, 9.765000, 9.652500
#*# 	9.687500, 9.722500, 9.740000, 9.750000, 9.697500, 9.607500
#*# 	9.682500, 9.710000, 9.732500, 9.847500, 9.672500, 9.587500
#*# 	9.702500, 9.730000, 9.755000, 9.747500, 9.692500, 9.607500
#*# 	9.717500, 9.750000, 9.775000, 9.750000, 9.667500, 9.625000
#*# 	8.415000, 8.472500, 8.402500, 8.512500, 8.427500, 8.297500
#*# tension = 0.2
#*# min_x = 30.0
#*# algo = lagrange
#*# y_count = 6
#*# mesh_y_pps = 2
#*# min_y = 30.0
#*# x_count = 6
#*# max_y = 340.0
#*# mesh_x_pps = 2
#*# max_x = 340.0
#*# [probe]
#*# z_offset = 8.0
Thank you…
