Since upgrading to version v0.12.0-37-g547bfbf8 I cannot get the Z axis to zero. I’m using Bltouch and was in the habit of manually zeroing the axis then changing the z_offset parameter in the [bltouch] section of printer.cfg. That section was commented out by PROBE_CALIBRATE. I also used to use g29 to do the bed leveling. Both have been removed from the current version. I have tried MANUAL_PROBE (followed by TESTZ) and the best I can do is to get the nozzle about 2mm above the bed when Klipper thinks z=0. Also followed the Bltouch section in the documentation, same result. The probe offset was 4.8 mm, which seemed reasonable. In any event the mounting bracket is not adjustable.
Printer Model: Creality Ender with Creality Sprite printhead, Bltouch
MCU / Printerboard:Creality Ender 4.2.7
Host / SBC Raspberry pi
klippy.log.zip (25.3 KB)
