Changed to a PT1000 and now ADCout of range
@TruWrecks
Before jumping in, it’s always a good idea to read through a thread.
If you had done that here, you would have seen that I made the same observation - although I noted that having a MAX31865 built onto an EBB36/EBB42 is a higher cost option.
If you had read further from my post, you would have seen that the MAX31865 isn’t absolutely required and that Klipper can be configured to use a PT1000 thermistor with the standard thermistor sensing hardware.
This was a learning experience for me, just as I hope this response is one for you.
It was solved, but thank you for your feedback.
Can you please mark the according post.
Thank you.
I had done so on one of sineos’ posts, but now I don’t see it anymore. Is it possible it erased because we continued the conversation?
I will mark it again but I am 100% sure I did it because it warned me it was solved before I gave Sineos feedback.
