Cleaning pass out of bed with CP V6 and an Ender-3 v3 SE
Printer Model: Ender 3 V3 SE
MCU / Printerboard:
Host / SBC raspberry PI3B
Hello,
I use my Ender since several months, and to improve the quality of my print, I have decided to use Klipper and a Raspberry PI3 to control my print. I have also dowloaded for the first time Creality print and also Orca. I have installed the printer from the parameters setting inside the program. For instance, there is a problem, the first pass to clean the head is just outside of the bed!! There is something wrong in the setup, but where?? As I have an error from the 2 slicers, I suspect a bad config in Klipper.
Thanks for your help
Michel
Hello @michastro !
Yes, where? Where is the klippy.log?
klippy.log (5.5 MB)
And the clean pass is just at the left of the bed.
What that Klipper version?
Git version: '1.0.0-373-g75dc4739'
recent version of Klipper is 0.12.0
You may read here: 3D Printers with Preinstalled and Modified Klipper Versions
OK, I am in factr stupid. Of course if the slicer hasn’t the PRINT_START macro called, it doesn’t work properly. Now its’ working.
Nevertheless, thanks a lot.
