cy0l
December 3, 2023, 6:09pm
1
Printer Model: Ender 6
MCU / Printerboard: SKR Mini E3 V3 & OctoKlipper on RPi4B
As the title says I’m trying to configure my Ender 6 to work with Klipper. I’ve followed multiple instructional guides online; How to install Klipper on the SKR Mini E3 V3 – YouMakeTech being the lastest one I tried.
I’m positive the wiring is done properly and that the firmware is built and flashed properly but i cant seem to get Klipper to get beyond standby or any of the buttons under the Klipper tab to become functional.
klippy.log (84.1 KB)
hcet14
December 3, 2023, 6:20pm
2
That’s written in your klippy.log
serial = /dev/serial/by-id/“your-mcu-id”
That “your-mcu-id” doesn’t make sense!
You could read the docs of Klipper or Sineos “Knowledge Base” before asking!
Have a look at " Connection Problems to the Printer Board".
Good luck, hcet14
cy0l
December 3, 2023, 6:48pm
3
Thanks for the link, I will begin to familiarize myself.
Sorry for old log, I have an updated one here
klippy.log (4.4 KB)
You have an error in your printer.cfg:
[printer]
kinematics = corexy
max_velocity = 500
max_accel = 2000
max_z_velocity = 10
max_z_accel = 100u
This should be:
max_z_accel = 100
and:
cy0l
December 3, 2023, 7:04pm
5
I seem to have solved the configuration file issues but now I am stuck with this screen.
Also, is it possible to force update of klippy.log?
Edit: New log
klippy.log (25.6 KB)
hcet14
December 3, 2023, 7:09pm
6
OctoKlipper?
That’s quite old fashion.
cy0l
December 3, 2023, 7:11pm
7
I like all the open source plugins and ability to monitor from afar.
But I’m open to suggestions, especially if this might likely be an OctoKlipper issue
Please don’t say that!
Some people like to work with it.
And: On OctoPrint, Klipper was developed.
Klipper Architecture / Ecosystem
Calling Klipper a 3D printer firmware is not complete to its full extent. In fact it is a 3D printing application with an associated ecosystem.
The following overview shows how the different aspects interact. Only the red boxes is Klipper in its original sense, the other boxes are independent products forming the entire ecosystem.
[Untitled Diagram.drawio]
Klipper Host
The core of the Klipper environment
Typically running on a Single Board Computer (SBC), …
hcet14
December 3, 2023, 7:49pm
9
EddyMI3D:
Ok, I’ll never say it again
All I wanted to state was: That’s just my opinion!
hcet14
December 3, 2023, 8:14pm
11
EddyMI3D:
“I prefer X before Y”
Sounds nicer than:
“Y is bad”
doesn’t it?
Are you addressing me? If yes, I don’t get it.
But back to the topic
[quote=“EddyMI3D, post:8, topic:12041”]
Klipper Architecture / Ecosystem Calling Klipper a 3D printer firmware is not complete to its full extent. In fact it is a 3D printing application with an associated ecosystem. The following overview shows how the different aspects interact. Only the red boxes is Klipper in its original sense, the other boxes are independent products forming the entire ecosystem. [Untitled Diagram.drawio] Klipper Host The core of the Klipper environment Typically running on a Single Board Computer (SBC), …
Do you remember
I’m planning to change how I handle new feature requests for Klipper. The current process involves submitters opening a PR on github and then a reviewer (typically me) provides feedback. Going forward I’d like to change to a process where feature enhancements are first discussed here on Klipper Discourse, and we can collectively get a sense of those features that are considered highest priority. I’d then like to focus my time on the coding and reviewing of those topics of high priority. …
Some of these “big ticket” items include:
The docs need to be upgraded so they recommend Mainsail/Fluidd/etc. instead of OctoPi/OctoPrint. This may also require changes to the install scripts in the main Klipper repo.
Sineos
December 3, 2023, 8:47pm
12
Well, it makes sense because:
They are specifically developed for Klipper only
Integrate Klipper more seamlessly compared to Octoprint
Easier to set up. OTOH, only when using KIAUH, otherwise quite impossible for the average Joe / Jane
Which does not make Octoprint any less great, and none of the “modern” solutions come close to customization possibilities that Octoprint is offering.
hcet14
December 3, 2023, 8:52pm
13
I didn’t say that. koconnor did.
cy0l
December 3, 2023, 8:54pm
14
so switch to Mainsail or Fluidd for a sustainable solution?
hcet14
December 3, 2023, 8:58pm
15
I would recommend that (just my opinion).
Sineos
December 3, 2023, 9:04pm
16
I do not see any immediate benefits of one over the other.
This largely depends on your requirements
If you just want a webinterface to click on “print” and jog around a bit then both will fully do
If you have special workflows or need special plug-ins then stick to Octoprint
If you feel comfortable with Octoprint, then stick to it
If you have the needed Linux skills and knowledge, you can run Fluidd, Mainsail and Octoprint in parallel
There is no real right or wrong. Try it and make up your mind.
