Printer Model:
MCU / Printerboard:
Ratrig Vcore 3
Octopus pro + sht42
Not and issue, only search advise…
Hi and merry Christmas to all…
For some time now I have been thinking about making a “test station”, and I have some doubts that I consult here in case you can help me and/or advise me.
The main use I would give to is to clean the hotend and test components that I don’t know if they are poorly connected, misconfigured or just don’t work…
I have to say that in the cleaning of the hotend I do it while it is hot. That’s the main problem I want to solve right now, since I don’t know if I’m cleaning the hotend or making a show for Cirque du Soleil…
I’ve seen two possibilities, there will be more
1- This is the one I like the least, I don’t think it’s comfortable. Buy a cheap MCU, to which you can connect a PSU, install Klipper, and the components to be tested
2- This is my favorite, to use an adjustable power supply and this is where I don’t know how to do it, some device, thermostat, that can read the thermistors used in the hotend, at the moment that of a Phaetus Rapid… Or even some device that would allow me to control the temperature without Mcu? A temperature controller capable of reading the thermistors of the hotend
- What components should I look for for the second option?
Thx
