Configuration problems with Vyper
Printer Model: Anycubic Vyper
MCU / Printerboard: TMC 2209
Klippy.zip (2.4 KB)
Hello - took the dive into using Klipper/Mainsail with my Vyper and have a Pi4 - trying to go through the steps to calibrate the Probe Z offset and bed mesh and get " ‘No trigger on probe after full movement’ message. I have a -3.00 value for Z - is this the issue? How do I correct it?
Also, I get a Moonraker warning on startup:
GCode path received from Klipper does not match expected location.
Received: ‘/home/chris/gcode_files’
Expected: ‘/home/chris/printer_data/gcodes’
Modify the [virtual_sdcard] section Klipper’s configuration to correct this error.
[virtual_sdcard]
path: /home/chris/printer_data/gcodes
I’d like to correct this. Thanks
Hello @christopherkramer !
What probe do you have exactly?
I haven’t added a probe to the Vyper - it’s mostly stock (only thing changed is the extruder - went with a BMG).
I assumed that I didn’t need to add one on…
¯\_(ツ)_/¯
I’m not sure about your model Chris but the Vypers I was just looking at come with what looks like an inductive probe.
I was actually able to figure the problem out - I had to change the Z to -6 to allow me to do both calibrations with no problems.
later on, there was an issue with the extractor when I tried to print (key 112 error) - here are the changes I made to the config file:
[gcode_macro PAUSE] Description: Pause the actual running print rename_existing: PAUSE_BASE Change this if you need more or less extrusion Variable extrude: 2.0
And in extruder add: max_extrude_cross_section: 2.0
I’m printing up the Voron Design cube as I type this… and it’s looking good!!!
Thanks to all… hope this helps someone in the future
