CoreXYUV support
Printer Model: selfmade
MCU / Printerboard: BTT Octopus Pro
I like CoreXYUV kinematics and I’d like to build one, but can’t really understand how to setup Klipper for it. Just for making it clear, saying “CoreXYUV” I mean a machine which has two almost independent CoreXY kinematics, but heads mounted on a common X gantry.
I’ve seen some discussions around CoreXYUV machines, but they didn’t really end up with something concrete, so lets rise the topic again
I’m a software developer (not C/Python, but I’m able to read the code) so I could try to dive deeper to the topic if somebody from more senior developers might mentor me a bit. As I understand the topic, I need kinda three dimensions: X1, X2 and common Y (are they called ‘rails’ in the code?) and four motors: X, Y, U, V. When moving X1 or/and X2, the movement may be independent. When moving Y (mo matter with or without X1/X2), the movement by Y should be duplicated to both heads and motor positions (X,Y) and (U,V) should be moved according to the new position.
But I don’t have an experience with C, so I can’t catch a good point in the code where I could do this kind injection.
Does anybody have any insight about this?
Currently, this is not supported, but the respective support is being worked on. See New generic_cartesian kinematics (incl. CoreXYU/CoreXYUV, generic IDEX and AWD)
