Basic Information: Screen is using : Desuuuu/DGUS-reloaded-Klipper
Printer Model: creality cr10s pro v2
Octoprint with plugin octoklipper
MCU / Printerboard: atmega 2560
klippy.log - >
klippy.log (2.7 MB)
Hello,
So I recently jumped for klipper. I installed it on my printer screen and MCU thanks to Desuuuu.
After methodically followed every steps, it is working fine (I can navigate in the menu after booting with octoklipper (connect). One thing is not working though, the Print Status :
This picture above should be seen on the screen when I start a print. Allowing me to make some adjustments. Unfortunatly, I’m being stuck on the home page, and if I try to access anything during print it says “busy”.
The only thing that I changed is
Optional - If you are coming from a different firmware, it is recommended to replace the T5UID1.CFG file in the DWIN_SET folder with the one available here.
By default, the flashing process only writes what's currently being flashed to its destination, leaving other areas of the memory untouched.
The T5UID1.CFG file provided here will erase the touchscreen onboard memory before the flashing process starts.
It is recommended to use this file when coming from a different touchscreen firmware.
I was coming from the tiny machine screen firmware so I wanted to remove the files. So I used this one instead.
Can you please enlight me on what to do ?
Is the probleme coming from octoprint?
