Detailed log of failed prints?
Is there any way to see a detailed log of the print job? Or activate a detailed log?
I ask because a couple of impressions have failed me, and when it bothers me the most, when it takes approximately 75%… and I would like to have more information about why it has happened, to try to avoid it…
Yes, it is true, that when the impressions failed, Moonraker said something about the reasons, but at the time I did not pay attention to it and restarted Klipper…
It was in case there was some way to have a detailed log… especially of failed prints… if not by default, maybe with a plugin or similar.
Thank you
P.D: Time ago,asked the same…
If you run Klipper on OctoPrint, you have the systeminfo bundle.
No… I use Mainsail in a Rpi…
The printer has a image for Rpi preconfigured…
All necessary information to diagnose are contained in the klippy.log file
