Ender 6 printing mirrored
Printer Model: Creality Ender 6
MCU / Printerboard: Bigtreetech skr mini e3 v3 0
Host / SBC Raspberry pi 4b
klippy.log (1.2 MB)
I have changed from ender original MCU to the skr mini e3 V3.0.
The printer is printing fine and the homing is in the back right that it should be.
The problem is that the printer is printing mirrored. I have searched for solution whith out luck. Tryed to swich cables between A and B (x and y) axis but no luck and also changed the motor direction.
I have set up what I can see like others on internet who use klipper and skr mini E3 V3.0 board, both hardware and printer.cfg file.
I hope that I can get help here to solve the problem.
Solved the problem. The position_endstop on X hade the value 0, but saw that the others on internet had it to max, so mine is 250, then after looked at Initial Startup | Voron Documentation there was i diagram for what to do with homing x y directions, so swop cables on the printerbord for the x and y connectors. Now the printer is printing as it shoud do.
