Endstops not working on SKR v1.1 board
I got an SKR mini v1.1 E3 DIP board. With 2209 drivers.
Wanted something small, since this is going to be in my small delta. Previously used Duet 2 wifi (excellent board) - without any issues. With Klipper. So I thought - how hard can this be.
I am unable to make the end-stops work , for some reason they do not respond .
Everything is configured and wired per spec.
I’m bit miffed as to what did I get wrong.
The board: pin out
Here’s the most relevant part of the config:
serial: /dev/serial/by-id/usb-Klipper_stm32f103xe_36FFDC054158303226681657-if00
#175
[printer]
kinematics: delta
max_velocity: 700
max_accel: 3000
max_z_velocity: 500
minimum_z_position: 0
delta_radius: 105
print_radius: 100
[stepper_a]
step_pin: PC6
dir_pin: !PB15
enable_pin: !PC7
endstop_pin: ^PC1
rotation_distance: 40
homing_speed: 20
homing_retract_dist: 5
homing_retract_speed: 10
second_homing_speed: 2
position_endstop: 220
arm_length: 215
angle: 210
[tmc2209 stepper_a]
uart_pin: PC10
run_current: 1.000
sense_resistor: 0.051
[stepper_b]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
endstop_pin: ^PC0
angle: 330
[tmc2209 stepper_b]
uart_pin: PC11
run_current: 1.000
[stepper_c]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC15
angle: 90
angle: 90
[tmc2209 stepper_c]
uart_pin: PC12
run_current: 1.000
Looks like this has been resolved. 2209 have two pins that had to be cut.
No information on this in docs.
Hello @greggj !
Where did you get that value from:
Referring to this, it is 0.110 Ohms
https://learn.watterott.com/silentstepstick/comparison/
BTW, this is the default value in Klipper.
And: What two pins?
