Everything works except Heaters
Printer Model: Voxelab Aquila
MCU / Printerboard: N32
Host / SBC rPi zero 2 w
klippy (1).log (942.1 KB)
I have an old Voxelab Aquila N32 board that I’m trying to convert to Klipper. I’ve followed all of the guides by PrintsLeo3d and everythings working fine except my extruder and bed are both reading 0 degrees and won’t heat. I still have the original thermistor in both, never been replaced. I know this is an older model with no company backing it anymore but any help would be appreciated.
Edit: I just printed on this printer 3 hours ago using Marlin and everything worked fine.
Hello @Mcclainja87 !
How did you got this Klipper version?
Git version: 'v0.10.0-778-gb4dd3890'
It is way out of date.
You may stick to this: Installing Klipper with KIAUH
Probably https://www.printsleo3d.com/s/N32Firmware.bin from KLIPPERAQUILA — PrintsLeo3D.
Welcome Mcclainja87,
yagi uses the same HW setup as you https://klipper.discourse.group/t/cant-get-printer-to-connect.
Why don’t you try to contact him? He set the thread to solved. Good luck.
Thanks for your comment! This made me realize that I did something wrong in setup and I redid the whole thing and it’s working now except about 20 minutes into pressure advance tuning I got this error:
MCU 'mcu' shutdown: Timer too close
So now I gotta go diagnose that.
Cool, for your new problem have a read here https://klipper.discourse.group/t/timer-too-close.
Please post a log with the new error.
Preferably in a new thread for this one with its issue is marked solved.
