Hi guys,
I recently Klipperized a Sapphire SP3, didn’t change anything except that I installed a BLTouch.
I’m getting extremely noisy readings from all temperature sensors, even the one in the MCU.
What could be causing this?
Hi guys,
This can be caused by EMI, a noisy PSU and/or bad grounding.
Thanks!
It seems to be a noisy PSU. I’ve enabled USB power, and as long as the PSU is turned off there is no noise on the readings.
Is there any fix for this, or do I need to buy a better PSU to get rid of this?
You may get rid of the noise by adding additional capacitors to the output lines of the PSU.
