FlashForge Adventurer 3 + BTT SKR Mini E3
I got fed up with the limitations of the proprietary hardware in my AD3, so I spent the last few months designing a Klipper based solution.
I need to publish the printed parts (tomorrow), but the overall solution is now working so I’ve published the config files and custom PCB’s (KiCad + Gerbers) to my GitHub.
FlashForge Adventurer 3 gets a new Brain, Hot-End and Klipper
Printed Parts are now Available:
https://www.printables.com/model/437968-flashforge-adventurer-3-klipper-revo-6-bltouch-btt
That’s so awesome. I was considering going down this path as well as some components in my mother board failed(camera and fans) and i was considering going down the BTT route as well. I may give it a try in the coming weeks once the switchwire project is complete.
Great work!
Thank you. I’m still fine tuning a few things like the Filament macros.
I’ve also just finished developing a solution to use an IR Z-Probe that can probe the entire bed.
Latest Prototype:
Extremely cool. Thanks for posting.
Starting with the print of the hotend, wish me luck
I hope it goes well. :+1:
I found these Mini Differential IR Height Sensors for $27 on Aliexpress, so I bought a couple to play with. They are more readily available that the Aussie made Z probe.
https://a.aliexpress.com/_mOULilS
Thanks for the reminder, always asked myself if I should have such sensors.
Found one on the Mellow site for only 10 € and two for less than 18€…
Ordered two for testing.
With regards to the PCB, it’s a bit harder to do one off pcb’s here in Australia, do you have spares when you made them? If you have spares I would be happy to pay for cost and shipping, the mod is printed, and is functional (tested on my switchwire build, so all good to go). I either have the choice of going down the PCB route or wiring harness, which isn’t the worst thing i suppose :slight_smile:
I think the IR height sensor is a good idea, i raided my arduino box and found that i have a few of these(when i was helping my niblings with electronic projects). Wondering what the accuracy level is like.
I’m not sure yet, I haven’t gotten around to putting my AD3 back together and testing it (too many projects on the go + Work :crazy_face: ). In theory the accuracy should be decent as the components used are very capable.
