Fluidd config missing
I have an ender 3 running klipper on a pi4 with Fluidd, installed about 6 months ago and all working as required. Yesterday when I turned on the pi, printer and connect to it with fluidd, I found that fluidd seemed to have reverted to default settings, ie all layout changes that I had made were lost, the colour scheme has changed and all my macro categorys had gone.
I have looked through all the log files but cannot spot any error messages, my printer still seems to work, but I am concerned that at least one file must have changed/disappeared so what else might go wrong.
Does anyone know where the macro categorys are stored in Fluidd ?
Any other ideas on what might have caused this ?
I have had a quick look around but failed to spot anything
Thank you
Ian
Hello @ibsmith04 !
How do you shut down the Pi?
Hi, All sorted now. It was caused by an upgarde to Moonraker which moved the data.mdb file in a default installation.
I close down klipper and the pi from within Fluidd, I don’t just power off.
Thanks for your help
:+1:
They way to do it!
Terminal
sudo shutdown -h 0
@NAPCAL :
I meant this instead of just pulling the plug :wink:
