Hi again,
I’m getting this message, I searched around tried a few things but still not corrected.
Also I’m not seeing any of my configuration files.
Thanks
printer.cfg (17.5 KB)
Hi again,
Thanks
The default_paramter_x option was deprecated more than a year ago, and fully removed from Klipper more than 6 months ago. See the link for more info. You’ll need to visit the Fluidd documentation page to get new macros that will work.
Hi thanks for responding,
I followed your suggestion had a look around but I basically know nothing about this stuff, to me it looks like what’s in there is good but obviously not. I just uploaded my printer.config if this would help.
Post your klippy.log. The posted cfg seems not to match the error.
I resolved that problem, what I have now is moonraker failing to load plugins. I think the file placement is the problem as i dont have any confiig files loaded in configuration.
klippy (24).log (114.6 KB)
moonraker (13).log (26.3 KB)
As you can see no files are in configuration
Cancel that, after 3 days of messing with this I’m no better off then when I started even after a clean install. Cannot get this going at all, I always had a small issue here and there when updating but nothing like this.
I’m not sure, where you are standing right now. In any case: If you need further support, please always just post a description of what you did and what the issue is together with a klippy.log showing the problem. If you changed something then post a fresh log.
Screenshots are not needed or helpful.
ok will do. Printer starts normally when I go to home I get this, Unable to read tmc uart ‘stepper_z2’ register IFCNT . The other problem is the very low probe and bed temps. I lowered the temps in printer.config so it wouldnt shut down but heaters still wont start.
klippy (25).log (47.1 KB)
Thank again
See TMC drivers - Klipper documentation
The klippy.log you posted does not show any errors.
Wow what a stupid mistake I had the board Id’s switched in printer configuration.
