Moonraker warning on Kingroon KP3S PRO V2
Printer Model: Kingroon KP3S PRO V2
MCU / Printerboard:
New in klipper community, dont understand why i keep seeing this problem.
Moonraker has failed plugins, please check your logs, update your configuration and restart moonraker.
  • update_manager
Moonraker warnings found.
  • Unparsed config section [update_manager] detected. This may be the result of a component that failed to load. In the future this will result in a startup error.
  • Unparsed config section [update_manager fluidd] detected. This may be the result of a component that failed to load. In the future this will result in a startup error.
  • Unparsed config section [update_manager KlipperScreen] detected. This may be the result of a component that failed to load. In the future this will result in a startup error.
  • Unparsed config section [update_manager octoeverywhere] detected. This may be the result of a component that failed to load. In the future this will result in a startup error.
When the error message already points you to the logs, it might make sense to attach them here. → moonraker.log
Generally speaking, check your moonraker.conf for the mentioned sections:
I don’t see any critical inconsistencies in moonraker.conf.
moonraker.conf (1.1 KB)
