Ok, the flash went, but still this error
Oh yes, it’s a new Klipper version.
Try this for M300
[gcode_macro M300]
{% set S = params.S|default(1000)|int %}
#default_parameter_S=1000
{% set P = params.P|default(100)|int %}
#default_parameter_P=100
SET_PIN PIN=BEEPER_pin VALUE={S}
G4 P{P}
SET_PIN PIN=BEEPER_pin VALUE=0
Thanks, I’ll try tomorrow
Ok no more error at M300, but now it stops at M355
Sorry to bother you, but I don’t know anything about coding.
Ok no more error at M355. I have mi this:
[gcode_macro M355]
{% set S = params.S|default(1)|int %}
SET_PIN PIN=LIGHT_pin VALUE={S}
Nice, looks like mine ![]()
[gcode_macro M355]
I also modified these parts
Can you tell me if this is correct?
[gcode_macro PARK_MACRO_0]
{% set X = params.X|default(0)|int %}
#default_parameter_X: 0
{% set Y = params.Y|default(0)|int %}
#default_parameter_Y: 0
{% set Z = params.Z|default(30)|int %}
#default_parameter_Z: 30
#gcode:
M117 Parking E 0
G91
G1 E-3.14 F1500
G1 Z{Z}
G90
G1 X{X} Y{Y} F3000
[gcode_macro PARK_MACRO_1]
{% set X = params.X|default(400)|int %}
#default_parameter_X: 400
#gcode:
M117 Parking E 1
G91
G1 E-3.14 F1500
G1 Z{Z}
G90
G1 X{X} Y{Y} F3000
So now I have this. This must be because my card is not in the machine and no connector is plugged in. Can you confirm it to me ?
My park macros are these:
[gcode_macro PARK_extruder]
SAVE_GCODE_STATE NAME=park0
G90
G1 X-43 F3000
RESTORE_GCODE_STATE NAME=park0
[gcode_macro PARK_extruder1]
SAVE_GCODE_STATE NAME=park1
G90
G1 X443 F3000
RESTORE_GCODE_STATE NAME=park1
If yours work, it’s fine.
Yes, you must have a connection to the T-Rex
Thanks again EddyMI3D for all your help.
The printer works under Klipper just one or two small messages telling me that it’s obsolete, but nothing blocking.
Now I need to find my star in end gcode for my slicer (Simplify3D) or Cura.
The nozzle fan spins as soon as the print starts, I’ll find.
If you have any leads, I’m all ears.
Hello
How to calibrate the right head extrusion (T1)
The G1 T1 E100 F25 command does not work. Does this tell me that a minimum temperature is required when it is 210°?
An idea ?
Thanks for your comments.
Did you change to the right extruder with a simple
T1
command beforehand?
Yes, I tried
T1
G1 E100 F10
But it doesn’t work
As far as I remember, T0 has to be heated to…
Try again with T0 at 180°C or so.
Hello,
In fact, this puts it in error, because the macro “[gcode_macro T0]” requests a parking of the primary head and it cannot do it because the origins (G28) are not done. Cura coding starts with T0.
The same concern for the second head.
I don’t know how to solve this problem.
Have you checked the start code in Cura?
This thread came active perfect timing for me. Could i see your start code for cura and possibly your config as it is now?
In my macro “T0” or “T1” I have the first line that worries me, and I wonder what it is for. Here is the line in question:
PARK_{printer.toolhead.extruder}
If I comment it, my error disappears.
Will this affect the operation of my printer?
