I want to be able to change the Rotation distance for X and Y axis in the Gcode, so I can compensate for ABS shrinkage.
How do you do it ???
There is no gcode to set the rotation_distance dynamically. In addition I would advise against it, since it is a setting that describes the hardware of your printer.
Such compensations belong to the slicer where you can easily scale your model according to your needs
