How to configure a hybrid corexy setup
Hey guys,
i’m trying to setup a core xy hybrid setup but i’m a bit confused on where each motor should go when configuring the hybrid corexy setup. Do both A and B motors go under the X axis and the Y is the only cartesian motors? I looked at the example config but i’m a bit confused as i have 3 motors and this is only listing two:
So i had to change the hybridcoreXY kinematics to make this work. Pretty much just added an extra rail for the Y and kept with the corexy calc_position:
# Code for handling the kinematics of corexy robots
# Copyright (C) 2017-2021  Kevin O'Connor <kevin@koconnor.net>
# This file may be distributed under the terms of the GNU GPLv3 license.
import logging, math
import stepper
class HybridCoreXYKinematics:
    def __init__(self, toolhead, config):
        # Setup axis rails
        self.rails = [ stepper.PrinterRail(config.getsection('stepper_x')),
               stepper.PrinterRail(config.getsection('stepper_y')),
               stepper.LookupMultiRail(config.getsection('stepper_z')),
               stepper.LookupMultiRail(config.getsection('stepper_aux'))]
        for s in self.rails[1].get_steppers():
            self.rails[0].get_endstops()[0][0].add_stepper(s)
        for s in self.rails[0].get_steppers():
            self.rails[1].get_endstops()[0][0].add_stepper(s)
        self.rails[0].setup_itersolve('corexy_stepper_alloc', b'+')
        self.rails[1].setup_itersolve('corexy_stepper_alloc', b'-')
        self.rails[2].setup_itersolve('cartesian_stepper_alloc', b'z')
        self.rails[3].setup_itersolve('cartesian_stepper_alloc', b'y')
        # Set traps and register step generators for non-auxiliary rails
        for i, rail in enumerate(self.rails):
            for s in rail.get_steppers():
                s.set_trapq(toolhead.get_trapq())
                toolhead.register_step_generator(s.generate_steps)
        # Register event handler
        config.get_printer().register_event_handler("stepper_enable:motor_off", self._motor_off)
        # Setup boundary checks for X, Y, and Z rails only
        max_velocity, max_accel = toolhead.get_max_velocity()
        self.max_z_velocity = config.getfloat('max_z_velocity', max_velocity, above=0., maxval=max_velocity)
        self.max_z_accel = config.getfloat('max_z_accel', max_accel, above=0., maxval=max_accel)
        self.limits = [(1.0, -1.0)] * 4  # Include auxiliary rail in limits for consistency
        ranges = [r.get_range() for r in self.rails[:3]]  # Exclude auxiliary rail
        self.axes_min = toolhead.Coord(*[r[0] for r in ranges], e=0.)
        self.axes_max = toolhead.Coord(*[r[1] for r in ranges], e=0.)
    def get_steppers(self):
        return [s for rail in self.rails for s in rail.get_steppers()]
    def calc_position(self, stepper_positions):
        pos = [stepper_positions[rail.get_name()] for rail in self.rails]
        return [0.5 * (pos[0] + pos[1]), 0.5 * (pos[0] - pos[1]) , pos[2]]
    def set_position(self, newpos, homing_axes):
            rail.set_position(newpos)
            if i in homing_axes:
                self.limits[i] = rail.get_range()
    def note_z_not_homed(self):
        # Helper for Safe Z Home
        self.limits[2] = (1.0, -1.0)
    def home(self, homing_state):
        # Each axis is homed independently and in order
        for axis in homing_state.get_axes():
            # Skip homing for the auxiliary rail directly
            if axis == 3:
                continue
            else: rail = self.rails[axis]
        # Determine movement for homing
        position_min, position_max = rail.get_range()
        hi = rail.get_homing_info()
        homepos = [None, None, None, None]
        homepos[axis] = hi.position_endstop
        forcepos = list(homepos)
        if hi.positive_dir:
            forcepos[axis] -= 1.5 * (hi.position_endstop - position_min)
        else:
            forcepos[axis] += 1.5 * (position_max - hi.position_endstop)
        # Perform homing
        homing_state.home_rails([rail], forcepos, homepos)
        # Synchronize the auxiliary rail with the Y rail
        #if axis == 1:  # Y rail
            #aux_rail = self.rails[3]
            #y_position = self.rails[1].get_position()  # Get Y rail's position
            #aux_rail.set_position(y_position)  # Set aux rail to match Y rail
            #self.limits[3] = aux_rail.get_range()
    def _motor_off(self, print_time):
    def _check_endstops(self, move):
        end_pos = move.end_pos
        for i in (0, 1, 2):
            if (move.axes_d[i]
                and (end_pos[i] < self.limits[i][0]
                     or end_pos[i] > self.limits[i][1])):
                if self.limits[i][0] > self.limits[i][1]:
                    raise move.move_error("Must home axis first")
                raise move.move_error()
    def check_move(self, move):
        limits = self.limits
        xpos, ypos = move.end_pos[:2]
        if (xpos < limits[0][0] or xpos > limits[0][1]
            or ypos < limits[1][0] or ypos > limits[1][1]):
            self._check_endstops(move)
        if not move.axes_d[2]:
            # Normal XY move - use defaults
            return
        # Move with Z - update velocity and accel for slower Z axis
        z_ratio = move.move_d / abs(move.axes_d[2])
        move.limit_speed(
            self.max_z_velocity * z_ratio, self.max_z_accel * z_ratio)
        axes = [a for a, (l, h) in zip("xyz", self.limits) if l <= h]
        return {
            'homed_axes': "".join(axes),
            'axis_minimum': self.axes_min,
            'axis_maximum': self.axes_max,
def load_kinematics(toolhead, config):
    return HybridCoreXYKinematics(toolhead, config)
This file can be found in /home/scoot/klipper/klippy/kinematics
in my config i used the standard corexy setup for the A and B motors (under x and y). then i added the extra Y motors under stepper_aux.
This seems to be working so far. I’ll update if i have any issues that pop up.
