i’m back from vacation too but sandly to me this means less free time but i’m still looking at it.
that’s my source for the reverse pin
this could be some random doc and even talk about a different version of the board but still to consider.
!!!UPDATE: probably the chinglish transation is just stating that the motor driver circuit board have to be mounted with a different phisycal orientation, and have nothing to do with the direction pin !!!
hope to be able to test something in the next days. meanwhile here is the config file i’m preparing so far, still lot to fix so please don’t consider it final in any way
# This file contains common pin mappings for the Makerbot
# Mightyboard. To use this config, the firmware should be compiled for
# the Atmel atmega1280.
[stepper_x]
step_pin: PD6
dir_pin: !PD7
enable_pin: !PD4
rotation_distance: 32
endstop_pin: ^!PC7
position_endstop: 152
position_max: 153
position_min: -120
homing_speed: 50
[stepper_y]
step_pin: PL5
dir_pin: !PL7
enable_pin: !PL4
endstop_pin: ^!PC6
position_endstop: 77
position_max: 78
position_min: -84
homing_speed: 50
step_pin: PL1
dir_pin: PL2
enable_pin: !PL0
rotation_distance: 8
endstop_pin: !PC5
position_endstop: 0
position_max: 230
position_min: 0
step_pin: PA3
dir_pin: PA2
enable_pin: !PA5
rotation_distance: 33.238
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PE5
sensor_type: ADS1118
sensor_pin: PE6
spi_software_miso_pin: PH2
spi_software_sclk_pin: PE2
spi_software_mosi_pin: PE7
control: pid
pid_Kp: 26.414
pid_Ki: 1.115
pid_Kd: 156.5054
min_temp: 0
max_temp: 280
[extruder1]
step_pin: PA0
dir_pin: PK7
enable_pin: !PA1
heater_pin: PE3
sensor_type: MAX6675
sensor_pin: PE6
control: pid
pid_Kp: 26.414
pid_Ki: 1.115
pid_Kd: 156.5054
min_temp: 0
max_temp: 280
[heater_fan extruder_fan]
pin: PH4
[heater_fan extruder1_fan]
pin: PE4
[fan]
pin: PG5
[heater_bed]
heater_pin: PH5
sensor_pin: PF3
control: pid
pid_Kp: 70.037
pid_Ki: 1.710
pid_Kd: 717.000
min_temp: 0
max_temp: 130
serial: /dev/serial/by-id/usb-MakerBot_Industries_The_Replicator_741373637373518160F0-if00
restart_method: stk500v1
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
Makerbot firmware sets x, y, a and b to 118 and z to 40 via eeprom defaults. Their software
sets x, y, a and b to 20 while preheating and then to 127 for printing (via G130). This
apparently was done to reduce power when preheating and may be a concern for Replicator2X
with heated bed and dual extruders? Need to see if this functionality is needed and implement
a command to set the digipots (currently can only be set via printer.cfg)
[mcp4018 x_axis_pot]
scl_pin: PA6
sda_pin: PD5
wiper: 1.0
scale: 1.0
[mcp4018 y_axis_pot]
scl_pin: PA6
sda_pin: PL6
wiper: 1.0
scale: 1.0
[mcp4018 z_axis_pot]
scl_pin: PA6
sda_pin: PL3
wiper: 0.315
scale: 1.0
[mcp4018 a_axis_pot]
scl_pin: PA6
sda_pin: PA4
wiper: 1.0
scale: 1.0
[mcp4018 b_axis_pot]
scl_pin: PA6
sda_pin: PJ7
wiper: 1.0
scale: 1.0
[display]
lcd_type: hd44780_spi
spi_software_mosi_pin: PC0
spi_software_sclk_pin: PC1
#miso not used, dummy pin.
spi_software_miso_pin: PJ3
latch_pin: PC3
click_pin: PG2
back_pin: PJ6
up_pin: PJ5
down_pin: PJ4
[output_pin lcd_power]
#has to be low for Rep2 low=5v, high=3.3v?
pin: PA7
static_value: 0
[output_pin lcd_led1]
pin: PC2
static_value: 1
[pca9632 led]
color_order: BGR
initial_BLUE: 1.0
initial_GREEN: 0.0
initial_RED: 0.0
[output_pin BEEPER_pin]
pin: PH3
pwm: True
value: 0
shutdown_value: 0
cycle_time: 0.001
scale: 1000
[gcode_macro M300]
{% set S = params.S|default(1000)|int %}
{% set P = params.P|default(100)|int %}
SET_PIN PIN=BEEPER_pin VALUE=0.5 CYCLE_TIME={ 1.0/S if S > 0 else 1 }
G4 P{P}
[gcode_macro START_PRINT]
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(190)|float %}
# Start bed heating
M140 S{BED_TEMP}
# Use absolute coordinates
G90
# Reset the G-Code Z offset (adjust Z offset if needed)
SET_GCODE_OFFSET Z=0.0
# Home the printer
G28
G1 Z5 F3000
G1 Z0.15 F300
# Wait for bed to reach temperature
#M190 S{BED_TEMP}
# Set and wait for nozzle to reach temperature
M109 S{EXTRUDER_TEMP}
[gcode_macro END_PRINT]
#M140 S0
M104 S0
M106 S0
G91
G1 X-2 Y-2 E-3 F300
# Raise nozzle by 10mm
G1 Z10 F3000
G90
# Disable steppers
M84
## <---------------------- SAVE_CONFIG ---------------------->
## DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
## [extruder]
## control = pid
## pid_kp = 27.746
## pid_ki = 1.666
## pid_kd = 115.493
