I’m using a Big Tree Tech Octopus board with TMC2208 in Uart. If I had a cartesian 3 axis setup with a stepper dedicated to each axis I could issue a gcode command that will rotate a specific stepper (G91 X100 for example).
I want to be able to do this for all 8 steppers I can connect to this board. I have found “none” kinematics and [manual_stepper] options in the documentation but I haven’t been able to find sample .cfg files to understand how to make this work. I want to be able to issue a gcode command like:
G91 motor_0 100 motor_1 200 motor_3 75 … motor_7 15
for example. I haven’t had luck finding anything and would appreciate any help! Thank you.
